Sponsored by:
Sponsored by:
Fog lights won't turn on - Electrical Problem
Old 04-06-2012, 07:32 AM
nfordhk
nfordhk's Avatar
Default Fog lights won't turn on - Electrical Problem
I recently ran over a big bump and my fog light came out and I ran it over . Then the cable dragged a little and the cap came off no big deal. The main connectors are still there and it fits tight in the new bulb connection after I got it replaced. However, neither of my fogs lights work anymore. I have also tried replacing the bulbs with my HID setup and it still wouldn't work.
I checked for fuses but I see these use a mini relay. I swapped it with 34 (says not in use and is the same type) but still no luck. I think it is an electrical problem because even though my daytime running lights never worked, that button still use to glow when I pushed it under my dash (well I think so haha). and it no longer lights up when I push it.
Is there 2 fuses for this that im not aware of? Any help would be appreciated.
nfordhk is offline
Old 04-06-2012, 12:41 PM
Art161
Art161's Avatar
Do you have the parking lights or headlights on, the high beams off, and the ignition switch in the ON position?
Art161 is offline
Old 04-06-2012, 12:46 PM
Nuke
Nuke's Avatar
http://iihs.net/fsm/?dir=40&viewfile=Fog Lamps.pdf
Nuke is offline
Old 04-06-2012, 02:14 PM
AzPete
AzPete's Avatar
I would look into the wiring where it got pulled out of the car. May have stretched something and broke a connection or a wire that cannot be easily seen.
AzPete is offline
Diode Dynamics
28
05-26-2022 12:02 PM
MustangHead91
08-23-2015 09:37 PM
inyadreems
08-21-2015 09:10 AM
KEM Motorworks
08-14-2015 10:13 PM
dseg
08-08-2015 09:00 PM
Quick Reply: Fog lights won't turn on - Electrical Problem
