Sponsored by:
Sponsored by:
Hot air coming from vents?
Old 04-11-2012, 08:53 PM
jrockgts197
jrockgts197's Avatar
It's pretty normal. Every single car I've ever owned had this happen in one way or another. I had a friend with a 96 Z71 truck that blew hot air through the floor vents horribly, which he called his "free heat" lol. I honestly think it comes from aging seals or mechanisms on the blend doors, which would explain why max A/C would temporarily alleviate the problem (recirculation mode, blend door shut). You're doing better than my co-worker, his windshield freezes from the inside in the winter, and no combination of climate settings on the dash can fix it as long as the truck is moving - and it's a 2011 model lol.
jrockgts197 is offline
Old 04-11-2012, 09:02 PM
pascal
S197 Section Modder-ator
pascal's Avatar
Originally Posted by Tarantula_Keeper
Why does it have to be my first car? No other car I've owned has done this and I've owned my mustang since 08 and it just started doing this this past winter.
It was sarcasm, lol.
Nuke is known to indulge in it since this past winter at least.
To stay on topic, check and see if your cabin air filter is OK or hasn't shifted.
That could be an issue, if not, the members already answered your question pretty much.
pascal is offline
Old 04-11-2012, 09:22 PM
onederful100
onederful100's Avatar
I am super **** about everything in my Mustang.
when the AC isn't on, i close the vents.
when the vents are closed they all must be perfectly horizontal.
in my honda civic, warm air comes in too. unless i switch the vents to circulate instead of outside air.
that is just like what another post said about switching to max AC for a second, then turn it off.
Max AC is recirculating the cabin air and closes the outside air vent.
onederful100 is offline
Old 04-11-2012, 10:30 PM
Goldenpony
Goldenpony's Avatar
My '06 has always done this too.
Goldenpony is offline
djbigskrilla
09-20-2022 01:04 AM
Calizic
08-28-2015 01:46 PM
69FB
08-18-2015 08:50 PM
HIS S-197
08-10-2015 05:47 PM
elraun
3.7L V6 Technical Discussions
08-09-2015 04:32 PM
Quick Reply: Hot air coming from vents?
