Sponsored by:
Sponsored by:
Radiator Boils, Fan only starts with AC on
Old 04-21-2012, 01:07 PM
buffboyali
buffboyali's Avatar
Default Radiator Boils, Fan only starts with AC on
Hello everyone. When I start the car the fan won't kick on unless I turn the AC on. The radiator boils after about 10 min with the fan off and car in idle. There is no coolant boiling out from under the cap. The upper part of my radiator is boiling. My car is 05 v6. Thanks.
buffboyali is offline
Old 04-21-2012, 03:34 PM
wayne613
wayne613's Avatar
Can ya plug it in to an ODB-II reader somewhere, say autozone? See what the thermostat is reading? My guess would be the thermostat is kaput since the fan "works". Just not being kicked on.
wayne613 is offline
Old 04-21-2012, 03:54 PM
Nuke
Nuke's Avatar
Here's the wiring info for the fan: http://iihs.net/fsm/?dir=40&viewfile=Cooling Fan.pdf
Any chance that you have a custom tune and the fan settings have been changed in the PCM?
Nuke is offline
Old 04-21-2012, 04:29 PM
wayne613
wayne613's Avatar
Yeah, I'd check those 2 fuses first, unsure if the A/C uses either of those. F40(15A fuse) and F3(40A fuse), both in BEC.
wayne613 is offline
Old 04-21-2012, 05:12 PM
buffboyali
buffboyali's Avatar
I dont have a custom tune. So far some people have said it can be the engine coolant temperature (ECT) sensor that needs to be replaced or the fan relays. I dont know what I should begin with checking.
Old 04-21-2012, 06:29 PM
AzPete
AzPete's Avatar
I would guess the relays are working since the fans work with the A/C. Check the ECT first.
AzPete is offline
Granatelli Sales
01-20-2020 12:34 AM
11-10-2015 11:39 AM
raleigh05GTO
09-04-2015 07:09 AM
09-03-2015 07:14 PM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: Radiator Boils, Fan only starts with AC on
