5.0 wont start condition
Old Sep 2, 2015 | 09:39 AM
5.0 kevo's Avatar
5.0 kevo
Default 5.0 wont start condition
I'm new to this site and have a problem I was hoping someone who had came across it can point me in the correct direction, I have a 1992 5.0 mustang gt, I was driving and as I shifted from first to second gear the car just died out on me, I pulled over I noticed the fuel pump does come on with key on ( fuel pump is new, just replaced with a 255 lph about 2 months ago) and the car will only start with starting fluid sprayed directly into the throttle body, and will stay on once car is revved ,once the car is warmed up it will start on on its own , I have half a tank of gas ,i have cleaned the fuel filter and the car still has the same problem.
Old Sep 3, 2015 | 02:56 AM
dawson1112's Avatar
dawson1112
Cold car needs a bit more fuel to get started,
Id check the fuel pressure with key on engine off. You ought to see about 34-36 psi at least. Don't think cleaning the fuel filter is gonna work they are meant to be replaced.
Old Sep 3, 2015 | 06:45 AM
88 orangepeel notch's Avatar
88 orangepeel notch
+1 ^^^
Let us know what your seeing for pressure, as it sounds like it's on the low side from either a bad pump or regulator.
Old Sep 3, 2015 | 10:01 AM
5.0 kevo's Avatar
5.0 kevo
Okay I will check and let yall know what its at, when I did clean my fuel filter there was a lot of fuel in the can,all I did was blow threw it in the opposite direction ,so I do think the pump is working correctly ,plus its fairly new and buzzes at key on, I appreciate yall helping me out thanks.
Old Sep 3, 2015 | 10:07 AM
5.0 kevo's Avatar
5.0 kevo
Originally Posted by 88 orangepeel notch
+1 ^^^
The pump is two months old and does buzz at key on, can a bad fuel pressure regulator really cause me to died out while driving? And cause a won't start condition? Is that common with our foxbodys?
Old Sep 3, 2015 | 06:16 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
buzz mean diddly......get a gauge on it and see what pressure is
Old Sep 3, 2015 | 06:24 PM
mjr46's Avatar
mjr46
also look for vaccum leaks
drfister
May 3, 2018 10:38 PM
MusicCity615
Sep 27, 2015 12:53 AM
SYNY5TER
Sep 2, 2015 01:35 AM
Omgitsa88Stang
Sep 1, 2015 06:31 AM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
