Sponsored by:
Sponsored by:
Exhaust leak..
Old 05-08-2012, 07:45 PM
Pope1122
Pope1122's Avatar
Default Exhaust leak..
So you all know how loud it is an what I did by the video, where the new h pipe connects to the old stock mid pipe where there are two clamps to close them together I have an exhaust leak. Makes car sound crappy on inside but it's so loud on outside you can barely but still hear it. Anyone know how to fix the leak right there? You can tell easy if you are listening for it
Pope1122 is offline
Old 05-08-2012, 07:53 PM
SpartaPerformance
SpartaPerformance's Avatar
What kind of clamps are they?
SpartaPerformance is offline
Old 05-08-2012, 08:11 PM
Pope1122
Pope1122's Avatar
The h pipe that I got said use the stock clamps so whatever kind of clamps they are, they are the ones that connet h to mid. The stock clamps, they are pretty tight so idk what I did wrong. The h pipe doesn't reach the mid, this clamp goes over the space between it thought that would make it leak but that's how the stock h was
Pope1122 is offline
Old 05-09-2012, 12:01 PM
bigblue95z
bigblue95z's Avatar
I think I know what clamps you're talking about. They're about 4-5" in length and have 2 nuts/bolts? Anyway, I don't think there should be any space between the pipes. They should butt together inside the clamp. When I put my OR-H on, I made sure to sand inside that clamp to get it smooth with no debris, as well as the stock pipe it connected to so I could have a clean surface press against as to try to avoid a leak. Could try that. And be sure to put some muscle behind it when you're tightening it.
bigblue95z is offline
Old 05-09-2012, 01:02 PM
Pope1122
Pope1122's Avatar
the leak was where the h pipe goes together with itself, and has a u lamp on it you know? anyway i fixed it now i just have to get some mufflers so i can drive it an not get ****ty looks
Pope1122 is offline
Dokilar
15
10-16-2015 08:13 PM
09-30-2015 12:39 PM
junior04
09-28-2015 10:53 AM
DtRockstar1
Mustang Videos
09-27-2015 07:46 PM
09-24-2015 09:18 PM
Quick Reply: Exhaust leak..
