Raxiom Switchbacks: resistor question!
I recently just received my switchbacks from AM and when I went to install them I temporarily just switched the stock bulbs with the LED's just to see if they worked and the polarity, while trying them out I found that they come on just fine with the parking lights (bright white) and flash between white and amber like they are supposed to when I turn on the turn signal without delay or going too fast. My question is if they work just fine without the resistors, then do I really need them? because mounting the resistors is a little bit of a pain in the a$$ to do, and I'd also have to re-sauter the connections because of the problem described below:
*As a side note look out for the wiring on the little resistors, the sauter and wire connections from Raxiom are very flimsy and with very little tension the wires on both resistors easily slipped off and out of the heat shrink. The quality of the bulbs is very good, but the quality in which the wires are attached to the resistors is very poor so you will have to re-sauter them yourself to make sure there is a tight/snug/secure connection.*
Yeah this is looking like what I will have to do, just a pain for a little led swap haha
gotta make sure the connectors are squeezed together really tight; i used tongue and grip pliers to do so. it was hyperflashing at first for me; but once i tightened all my connectors it was fine. hope this helps
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
2011, 2012, install, installation, installing, led, mustang, raxiom, resistor, resistors, signal, switchback, switchbacks, turn
