Last edit by: IB Advertising
Browse all: General Overview
- Ford Mustang V6 and GT 1994 to 2014 Warning Lights
Important information to help you understand your Ford Mustang.
2007 Mustang v6 Wrench warning light
Do you know someone with an ODB-II reader? Autozone or any local auto parts store will read the codes for free, but obviously in limp mode that is likely not feasible.
The likely answer since you swapped the TB, is something related to it of course, so I'd double-check everything, no bent pins, TPS is put back in right, TB is clean, MAF cleaned and connected properly, etc..
You did have to swap it and some other things for the after-market BBK one, yes?
Okay so I unplugged the negative for more than 20 min and I still have this issue ;/
Should I buy an ODB-II reader to cancel the warning light ?
