Sponsored by:
Sponsored by:
Dreaded rear view mirror rattle in '10 cheap fix
Old 06-06-2012, 09:18 PM
wcgman
wcgman's Avatar
Default Dreaded rear view mirror rattle in '10 cheap fix
My 10 picked up that really annoying buzzing/rattle from the rear view mirror probably about 12k miles (4k miles ago). Some days worse than others, but can make it happen consistently between 80 and 85.
I found by lightly touching the power connector on the back of it, the rattle went away. So today I grabbed one of the soft felt velcro cable tie wraps from work (usually for CAT5 network cable, etc...) and wrapped it fairly lightly around where the power coupler goes into the back of the mirror and the rattle went completely away.
If you cant get them at work, you can find them at office supply stores like office max/depot and walmart target. Just look for cable wraps that are the velcro ones and softer material. I found one the perfect size, but a larger one can be trimmed to fit easily and you cant see it at all.
wcgman is offline
Old 12-06-2013, 11:51 AM
Mulepick
Mulepick's Avatar
I applied some clear silicon around the mirror plug making sure not to get any into the female electrics. Plugged it back in and after 2 days all rattle is gone except for some slight rattle over the roughest road. All this at 29 degrees.
Mulepick is offline
Old 12-06-2013, 05:05 PM
rt66er
rt66er's Avatar
I fixed mine by yanking it out and installing a manual dim mirror. The auto dim never worked to my satisfaction; too slow to dim and it never got dim enough for my taste. I lost the compass function, but I pretty much know which direction I'm goin' anyway.
rt66er is offline
drfister
05-03-2018 10:38 PM
JonnyBlazeGT
11-03-2015 01:10 AM
alymac
08-26-2015 07:46 AM
kiwi4100
08-18-2015 10:45 AM
kiwi4100
08-16-2015 08:39 PM
Quick Reply: Dreaded rear view mirror rattle in '10 cheap fix
