is oil filter on to tight?
Hay guys i changed my oil last night and im not sure if i put the filter on to tight!! i hand tight the filter until i couldnt turn it anymore with two hands. i was worried that if it wasnt tight enough it would leak but a tech told me not to over do since it gets tight as time goes on!! should i be worried? can i loosen the filter and tight it up a little again?
I'd say your ok. I've never seen an oil filter that was on to tight fail. And I seen one that took two of us to get off and it was still working. I might be a little of a pain to get off next oil change but I'd rather be to tight than too loose.
The only issues with overtightening the oil filter (which you did NOT do by hand unless you're King Kong) are:
- crushing/deforming the o-ring in which case you'll have a nice mess under the car when you start it
- require the vice-grips from hell to remove the filter next oil change
Man, take your Ritalin!!!
Relax, it's fine. IMO, if you can untighten it by hand after it's had a couple of heat-up/cool-down cycles, then it's too loose. Buy a filter wrench for future oil changes because if it comes off by hand, you have more possibility of something going wrong then if it's a bit too tight.
P.s. oil filter wrenches are beautiful things, invest in one.
