Sponsored by:
Sponsored by:
How much air is in your tires? PSI?
Old 08-06-2012, 12:29 PM
  #21
flash gordon
flash gordon's Avatar
Originally Posted by Art161
I have the OEM Pirelli 235/55ZR17, for which 32 psi is recommended. I check with a dial gauge on a monthly basis, but don't like to bother adjusting the pressure that often. When I add air, I inflate all tires to 35 psi. They all lose about 1 psi per month, so when the pressure gets down to 32-33 psi, I add air. If I'm going to travel on a winding back road, I sometimes inflate to 32 psi because the car seems to handle better.
BTW, there might be something beneficial about nitrogen. My neighbor, who is not interested in cars, has nitrogen in his tires. I check the pressure for him occasionally, and they rarely need inflating.
Besides Costco, which only fill the new tires with nitrogen, where can you get nitrogen?
flash gordon is offline
Old 08-06-2012, 12:51 PM
  #22
Art161
Art161's Avatar
Don't know. My neighbor bought his tires at Costco.
Art161 is offline
Old 08-06-2012, 08:35 PM
  #23
Nuke
Nuke's Avatar
Nitrogen... If you have to pay more than $5 total, you've been ripped off.
Nuke is offline
Old 08-06-2012, 09:01 PM
  #24
My1stGT
My1stGT's Avatar
17 rear 43 front!
My1stGT is offline
Old 08-06-2012, 09:42 PM
  #25
slyter485
slyter485's Avatar
Most dealerships will have nitrogen too, but they are expensive from what I've been told..
Running 245/45R19 and have 35psi all the way around.
slyter485 is offline
Old 08-06-2012, 10:15 PM
  #26
MadStang40
MadStang40's Avatar
Wow, seems I'm just a little bit high according to the general consensus on these boards.
255/40/18 and 275/40/18 NT555s 36PSI all 4 corners
MadStang40 is offline
Old 08-07-2012, 03:05 AM
  #27
Rockmonster
Rockmonster's Avatar
Factory recommends 32psi on my stock tires. Max pressure is 44psi. I have at just under 40psi.
Rockmonster is offline
Old 08-07-2012, 10:05 AM
  #28
2005Redfire6
2005Redfire6's Avatar
Generally 35 Front, 32 Rear. But, I have been running 35 all around lately.
2005Redfire6 is offline
Old 08-07-2012, 10:27 AM
  #29
Nuke
Nuke's Avatar
FYI: Max pressure stated on the tire sidewall is NOT an operating pressure. Even the tire manufacturers state to inflate to the car manufacturers recommended inflation listed on the door frame placard.
Nuke is offline
Old 08-07-2012, 11:26 AM
  #30
Toxix
Toxix's Avatar
Originally Posted by xkape
20's.. Cooper RS3 tires. 275/35Z
I am definately a fan of 32psi. When I had my tires Road Force balanced, the guy filled them to 40psi. On the drive home I felt like I was floating. That is NOT... a good feeling to have while going 65..lol So I dropped them to 32 all around. The low tire pressure light comes on for about 10 seconds every time I start my car now though.
My pressure light is on 24/7. No TPMS in aftermarkets (wouldn't fit)
I'm going to follow in your footsteps...I'm sitting at 38-40 now, gonna give 32 a shot.
I've called several shops, and they're asking $20 PER TIRE a fill for Nitro...lol unbelievable.
I'll stick w/ my gas stations, even if it means more frequent stops to fill up air.
Toxix is offline
Quick Reply: How much air is in your tires? PSI?
