Sponsored by:
Sponsored by:
05-09 gt oil pressure readings?
Old 10-19-2012, 08:41 AM
white08gt
white08gt's Avatar
Default 05-09 gt oil pressure readings?
for those that have added a real gauge, what pressure are you seeing at idle and cruising speed ? yes, i have tried the search button.
white08gt is offline
Old 10-19-2012, 08:53 AM
nolimits
nolimits's Avatar
What kind of pressure are you seeing? Typically I'd say anywhere around 20psi increasing to around 40ish at cruising.....60-80 at redline would be a safe range for any motor. I don't have any exact "5.0" numbers, though to help, sorry.
nolimits is offline
Old 10-21-2012, 03:19 PM
doode
doode's Avatar
Cold start = 80
Warm idle = 38-40
warm under load = 70-75
warm coasting = 50
Autometer gauge tapped into an oil filter sandwich adaptor
doode is offline
Old 10-21-2012, 03:21 PM
obxdude018
obxdude018's Avatar
Originally Posted by doode
Cold start = 80
Warm idle = 38-40
warm coasting = 50
That's about right for me as well, believe my idle is slightly lower.
obxdude018 is offline
Old 10-21-2012, 05:12 PM
RedFire281
RedFire281's Avatar
Cold start = 80
Warm idle = 38-40
warm coasting = 50
About the same for me but my warm idle is between 22-25. I also have an Autometer tapped into an oil filter sandwich adaptor.
RedFire281 is offline
Old 10-22-2012, 04:23 PM
moosestang
moosestang's Avatar
Is everyone using 5w20?
moosestang is offline
Old 10-25-2012, 12:21 AM
doode
doode's Avatar
mobil 1 5w20 for me
doode is offline
Old 10-25-2012, 09:23 AM
white08gt
white08gt's Avatar
i teed off the where the factory sending unit was. warm idle 34 lbs and 65 lbs cruising. using speedhut legacy gauges, water temp runs around 185 without running air and 190 with air on. if you don't know about the speedhut gauges you need to ckeck them out, they come in about 3 levels, i chose mid grade over the base because of better sending units and you can custom build them to your liking for the same price.
mtgldr
02-03-2024 09:00 PM
StalkerGT
09-25-2015 02:41 PM
GimpyHSHS
09-18-2015 12:27 PM
MusicCity615
09-12-2015 07:05 AM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: 05-09 gt oil pressure readings?
