Sponsored by:
Sponsored by:
Brake upgrade options?
Old 04-07-2013, 09:51 PM
baddog671
baddog671's Avatar
Default Brake upgrade options?
I remember reading that the 2011+ brakes are larger than my 06's and with a bracket can bolt up. Any information on this? Thanks
baddog671 is offline
Old 04-07-2013, 10:48 PM
edwin108
edwin108's Avatar
The 2011+ non-Brembo GTs have 13.2" front rotors while the 05-10 GTs have 12.4" rotors. To upgrade, you only need the rotors and caliper brackets. Roush overstock has them for $150
http://www.ebay.com/itm/FORD-MUSTANG-13-2-FRONT-ROTORS-CALIPERS-AND-BRAKE-PADS-NEW-TAKE-OFF-OEM-/281058367087?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item417062566f
edwin108 is offline
Old 04-07-2013, 11:04 PM
07BLACKGT
07BLACKGT's Avatar
^Wow that is fantastic!! Thanks for the link. I might have to pick some of those up too at that price.
07BLACKGT is offline
Old 04-07-2013, 11:09 PM
livewr06
livewr06's Avatar
I've seen people talking about these kits lately and saw this as a good way to upgrade my brakes. I was curious if I need mounting brackets, or does the kit come with them?
livewr06 is offline
Old 04-07-2013, 11:17 PM
edwin108
edwin108's Avatar
This kit comes with the caliper brackets. As a plus, you also get a spare set of calipers and pads. I think you need 18" wheels or larger for the rotors to clear though.
Last edited by edwin108; 04-08-2013 at 07:38 AM. Reason: Added info about wheel size
edwin108 is offline
Old 04-08-2013, 07:49 AM
baddog671
baddog671's Avatar
Ford Mustang 13 2" Front Rotors Calipers and Brake Pads New Take Off | eBay
Thanks for the link. I added it to my "watch list"
Cant go wrong with rotors, pads, calipers, and brackets shipped for 150! That's about what it would cost locally just for the rotors and pads.
Do you know if there is an upgrade for the rear brakes as well? I looked in their other auctions and only thing I found was 2012 rotors (11.8") and says it will fit 2005-2012, but I don't know the stock size of my 2006 rear breaks.
Old 04-08-2013, 08:07 AM
edwin108
edwin108's Avatar
As far as I know, all S197s share the same rear brakes (11.8") except for the 2013 GT500 (13.8"). You can upgrade the pads though; I think my 2010 TrackPack has pads made by Performance Friction.
edwin108 is offline
Old 04-08-2013, 08:17 AM
Bullitt2059
Bullitt2059's Avatar
Just wanted to chime in and say I did this upgrade about 2 weeks ago, and its been great. Have'nt really pushed it yet, as I also got new pads so letting them bed in a bit more, but the upgrade went flawlessly. absolutely need 18inch rims though, the space between my caliper and rim is very small at this point. I got the whole kit from Roush, as it included the brackets which are expensive if bought separately, and the rotors, but i only used the brackets and rotors as my calipers were in great shape and the fluid was recently changed.
Bullitt2059 is offline
Old 04-08-2013, 08:21 AM
baddog671
baddog671's Avatar
I was considering these for pads, unless I got better suggestions.
http://www.americanmuscle.com/proact...ds-0513gt.html
http://www.americanmuscle.com/proact...pads-0513.html
Old 04-08-2013, 08:24 AM
Bullitt2059
I would say if you are looking for OE replacment pads, and not higher temp pads, just use the stock pads that come with that Roush kit. I ended up getting Hawk HPS pads to go with the setup as I wanted something with a bit less fad, but the pads that came with the kit were in perfect shape.
Quick Reply: Brake upgrade options?
