Sponsored by:
Sponsored by:
What aftermarket tire psi?
Old 08-06-2013, 12:50 PM
luckydawg003
luckydawg003's Avatar
Default What aftermarket tire psi?
What Psi should I be running in my Nitto Invo's. Front are 255/45/18 . Rear are 275/40/18. I had the fronts at 32 and rear at 36, but the tire shop guy bumped all four up to 50 psi. I think thats too high, but not sure since aftermarket tires don't tell you what psi to run them at, only the max is listed.
What psi should I use?
luckydawg003 is offline
Old 08-06-2013, 01:27 PM
Nuke
Nuke's Avatar
What I do whenever I buy new tires is start with what's on the door placard and work up or down from there in 2 PSI increments. Since I prefer a bit of over-inflation from what's recommended, I'm usually at about 2-6 PSI above the placard but it usually depends on the tire and how I'm driving it. At 50 PSI, your "footprint" is likely limited to the 1/2 - 2/3 of the tread width from the center. The guy at the shop is a moron.
Nuke is offline
Old 08-06-2013, 01:36 PM
Derf00
Gentleman's Relish
Derf00's Avatar
+1 on almost all of it.
The dude at the shop should not be working there. I bet the 50Psi he put in was the MAX listed on the tire?
Derf00 is offline
Old 08-06-2013, 01:41 PM
AMWill
Former Sponsor
AMWill's Avatar
I agree with these guys ^^^. 50psi is the max rating for the tire and NOT what you should run at any point in time on the street. I would stay around 32psi for both tires. You can move up and down from there until you find something you like, but not too much higher.
Hope this helps!
Shane
AMWill is offline
jwog666
12-27-2021 08:09 PM
TCStangerv6
10-11-2015 05:57 PM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
09-24-2015 09:18 PM
Quick Reply: What aftermarket tire psi?
