Steering shake at 60mph
Still had the shaking though. So road force balance and found one tire, on the rear, was causing it. Replaced it and all was fine, until about 3 weeks ago and the shaking started back up. Stopped at Discount Tire where I purchased the tires and asked them to do the road force (they call it something else) - and a problem was found with a second tire on the rear. Replaced that one and no shaking.
Particularly if you know the week/year of manufacture and the batch number of each bad tire, you may want to report it to NHTSA. It appears there was a bad batch or two manufactured.
Just to update you guys - I was at the at dealer that I usually go to . There's a camber adjustment required on both the front wheels . So going in for alignment on Wednesday . Will also do the road force balance .
Once of tr things that came up - the mechanic wanted to know whether 2007 mustangs have the camber kit installed ? He checked the specs but couldn't positively determine it . Is there a way for me to find out that before I take it back day after ? I did see a YouTube on how to install it but how do I know if my mustang has it ?
I got after market tires - fuzion . On a visit to a dealer I usually go to, he said I have a positive camber.
Can alignment and road force balancing be done at different times or do these have to go together ?
The mechanic wasn't sure whether 2007s came with a camber kit . He said that will be required for alignment . Can anyone throw some light on that ? If that is indeed required, are after market camber kits reliable or do I have to buy it from the ford dealer ? Thank you folks !
Updating this just in case its helpful to someone in future.
I got my steering shake resolved. There was a play in the inner and outer tie rods. They were replaced, wheels road balanced and the problem is gone. Thank you all.
