Lowering Springs help
So I'm looking to lower my 05 GT, but I only want to lower the rear suspension. Would I have to buy anything other than the springs? Also does anyone have any recommendations on what type of springs I can buy. Thank you for the help I am new at this
I used the Roush rear springs on my 2006, and later swapped for the FRPP springs. The Roush dropped it a little more than I liked.
To install them you will need a spring compressor. You can rent one from AutoZone and similar places, or buy one at Harbor Freight.
I found that the ride was really bouncy until I cut the top off the bump stops.
If you drag race you will want some relocation brackets to level the rear lower control arms again.
And you should get new shocks. Running lowered on the stock shocks will cause them to wear out quicker. You have some time, but start looking.
Depending on how low you go in the rear, you might need new bump stops too. I've heard of folks cutting them but they aren't pricey for lower ones. I've lowered a few stangs including the rears only and it looks good. Also should help with your launches assuming they are progressive rates.
I want to get a 1.5" drop but been scared because my car runs great now and i dont want to cause any problems....also im scared about what other suspension things i will need, ie: i called AM several times, and some reps say i just need springs, and some say i just need camber botls and springs, and some say i need camber plates, bolts, springs, panhandle bar.... so im scared to jump on it, even though i think it would look really nice
