Sponsored by:
Sponsored by:
P0430 code
Old 05-05-2014, 01:27 PM
yourmyboybh1026
yourmyboybh1026's Avatar
Default P0430 code
So I've had my new LTs and catted x-pipe on my car for about a week and this morning that code popped up. Its P0430 "catalyst system efficency below threshold bank 2"
Question is, will this damage anything, what causes it and how do I fix it?
yourmyboybh1026 is offline
Old 05-05-2014, 01:36 PM
edwin108
edwin108's Avatar
I believe that's caused by the rear O2 sensors finding the new cats to be less effective than the OEM ones. Disabling your rear O2 sensors in the tune would make the code go away, but you wouldn't be able to pass emissions testing. You can also install O2 non-foulers to raise the sensors out of the exhaust stream.
edwin108 is offline
Old 05-05-2014, 02:16 PM
jz78817
jz78817's Avatar
no, aside from the check engine light being on, and if you're in a state which does emissions inspection it'll fail.
what causes it
your new catalytic converters don't work very effectively. The upstream (pre-cat) O2 sensors are used by the PCM for air:fuel management; the downstream (post-cat) O2 sensors are used by the PCM to make sure the cats are there and working. If the signal coming from the upstream and downstream sensors are too similar, you'll get "catalyst efficiency" codes.
either put the stock cats/pipe back on or find something that'll ignore the downstream sensors.
jz78817 is offline
Old 05-05-2014, 03:04 PM
yourmyboybh1026
Ok, well as long as its not going to damage anything I'm ok with it. I'm putting on a supercharger this weekend and turning off the rear O2s anyway. I don't have emissions testing here in FL, but I put the cats on just in case I moved to a state that does. I'll worry about it then if I need to. Thanks guys.
BOB ROME
07-26-2023 01:54 PM
mrtrodonet
09-19-2020 03:12 PM
lincolnshibuya
12-08-2015 04:37 PM
Dathan
10-05-2015 05:52 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: P0430 code
