Sponsored by:
Sponsored by:
Air conditioning woo's.
Old 05-08-2014, 12:53 PM
moosestang
moosestang's Avatar
I would have taken it to another dealer after the first non-fix. Maybe you have only one dealer close by, i don't know, but not all service departments are created equal. Having to send a Ford engineer to fix an A/C looks really bad on ford part.
Take it to an independent mechanic and sue ford in small claims court. They probably won't even show up.
moosestang is offline
Old 04-15-2015, 03:53 PM
tbenson
tbenson's Avatar
Problem is most likely the hot water cutoff switch is not shutting off the hot water flowing to the coil under the dash.
tbenson is offline
Old 04-15-2015, 04:56 PM
DRAGUL
DRAGUL's Avatar
Did they remove the refrigerant and pull a good vacuum on the system, or did they just check pressures? Your system could be contaminated.
DRAGUL is offline
Old 04-15-2015, 07:21 PM
cruisin5268d
cruisin5268d's Avatar
This thread is a year old. Welcome to the forum. Always check dates before you post.
cruisin5268d is offline
Old 04-16-2015, 05:24 PM
tbenson
tbenson's Avatar
I realize that the issue is over a year old, however, I have found many solutions to problems that were posted in old posts.
tbenson is offline
baddog671
07-26-2016 01:20 PM
winner99
10-01-2015 01:06 PM
mdg
10-01-2015 07:04 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: Air conditioning woo's.
