Sponsored by:
Sponsored by:
Little help reading datalogs
Old 07-23-2014, 05:13 PM
dlazrael
dlazrael's Avatar
Default Little help reading datalogs
I am attaching all my data logs, dated as they are with communication to BAMA. BAMA says there is an air leak, I am also attaching my leaktest I did, with the following: I sprayed each item approximately 15 second intervals. In this order:
just behind MAF, First CAI rubber joint, Second CAI rubber joint, TB, Inlet Elbow, Gear Case, Drvr Side S/C to Intake, Drvr Side fuel injectors, Drvr side intake to head, Vacuum bypass valve, Pass side S/C to intake, Pass Side injectors, Pass side intake to head.
I don't know how to make ups or downs of the graphs, any help would be appreciated, so I know where to fix this god blasted air leak
https://www.dropbox.com/sh/hff4nlad0...lPfVNCIee5oD-a
I think that link will work, Not really used to sharing with dropbox...
dlazrael is offline
Old 07-23-2014, 05:17 PM
dlazrael
dlazrael's Avatar
Here on google drive incase dropbox doesnt work:
https://drive.google.com/folderview?...W8&usp=sharing
dlazrael is offline
chrisdbassplayer
10-13-2015 06:53 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Dathan
10-05-2015 05:52 AM
09-27-2015 03:16 PM
jc409
Convertible Tech
09-26-2015 08:28 AM
Quick Reply: Little help reading datalogs
