Sponsored by:
Sponsored by:
2005 Blower Fan Speed
Old 07-24-2014, 12:40 PM
rcazwillis
rcazwillis's Avatar
Default 2005 Blower Fan Speed
Just picked up a 2005 Mustang with 131k on the odometer. Number issues needing addressed. First one is the fan speed for the AC. Feels like it is on low. Speed switch does not change fan speed. Air is cold. Changing the blower motor resistor did not fix the issue. Is this a switch issue?
Advice is appreciated.
rcazwillis is offline
Old 07-24-2014, 08:12 PM
2005Redfire6
2005Redfire6's Avatar
Sounds like the switch, I would be sure it is completely secured/plugged in. I removed that panel before and somehow managed to either put the plug in upside down or not all the way seated (can't tell cause of no lighting, etc) and it caused the switches to not work properly. After playing with it a little all is back to normal.
2005Redfire6 is offline
Old 07-24-2014, 10:02 PM
rcazwillis
rcazwillis's Avatar
That is the direction I am headed. Previous owner changed the head unit out before selling the car. Looks like you have to take the front panel off to get to the unit. I am hoping he did not get it plugged back in well. Thanks for the feedback.
Old 07-25-2014, 08:35 AM
SteveDwsn
SteveDwsn's Avatar
More than likely, it is not plugged in. The wiring harness is quite short and you almost have to plug the connecter in to the switch connector after the dash panel is in place. Make sure you hear the 'click' when you plug it in.
SteveDwsn is offline
Old 07-25-2014, 02:39 PM
rcazwillis
rcazwillis's Avatar
Switch was unplugged. Took about three minutes to get the console apart and the plug found. Plugged up, fan works.
Old 07-25-2014, 08:28 PM
Goldenpony
Goldenpony's Avatar
Good deal. Don't you wish all problems were that easy to fix?
Goldenpony is offline
Old 07-25-2014, 11:28 PM
rcazwillis
rcazwillis's Avatar
Most definitely. The axle bearing I am changing tomorrow would be a good starting point.
bjdutch2005
03-24-2017 03:38 AM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
Seanam
10-04-2015 10:15 AM
jaiidutch
09-14-2015 10:29 AM
Quick Reply: 2005 Blower Fan Speed
