Sponsored by:
Sponsored by:
wtf is this
Old 11-04-2014, 12:36 AM
13'GT Black
13'GT Black's Avatar
Default wtf is this
plasti dippin my wheels today and when i took my driver rear wheel off i found this
https://dl.dropboxusercontent.com/u/...103_145651.jpg
https://dl.dropboxusercontent.com/u/...103_145707.jpg
i only had time to do this wheel only so not sure if its the same on otherside.
13'GT Black is offline
Old 11-04-2014, 04:31 AM
slipperman
slipperman's Avatar
it's a chip.
The axle has a center drill in the end for manufacturing purposes and in a machine shop, metal chips can end up anywhere.
one got wedged in the pilot of the center drill hole and remained throughout the rest of the assembly process.
Pluck it out and be on your way. Or not.
slipperman is offline
Old 11-04-2014, 05:46 AM
Moderator
JimC's Avatar
Embeded your pictures for you
JimC is offline
Old 11-04-2014, 10:14 AM
13'GT Black
Originally Posted by slipperman
it's a chip.
I didnt know what it was so i left it alone lol. Thanks.
Old 11-04-2014, 12:48 PM
Derf00
Gentleman's Relish
Derf00's Avatar
it's a chip.
Yep, left over machining shard. Needle nose pliers will pluck it out. It won't hurt anything if you left it in there.
Derf00 is offline
Old 11-04-2014, 05:29 PM
13'GT Black
im so mad, finished dipping my wheels today and excited to put them on then **** happened. For some reason on one of the wheel dip came twisting off when tightening my lug nut. Try loosening but dip also starting twisting..... Ill need to redo it tomorrow. But my car looks alot meaner now with matte black wheels. Window tint willbe next.
Old 11-05-2014, 07:50 AM
algregory
algregory's Avatar
On the Window Tint, make sure to look at discussion about Moleskin. I'm on my second set of tinted windows. Next time Moleskin for sure!
algregory is offline
Old 12-20-2014, 10:38 AM
157dB
Cut & Paste Expert
157dB's Avatar
Plasti-dip in between the lug nut seat and the lug nut taper in the wheel
is a big no-no.
The lug nuts will not stay tight without full metal to aluminum contact.
Try putting a nickel in the lug nut opening BEFORE spraying the rims.
Then remove it while the plasti-dip is still tacky/wet. You will be left
with clean lug nut tapers in the wheel, no plasti-dip tearing and the
lug nuts will stay tight...
I have a few wheel plasti-dip painting sessions under my belt...
Attached Thumbnails wtf is this-plastidipt-18s.jpg   wtf is this-plastidipt-18s-2.jpg   wtf is this-plastidipt-18s-3.jpg
157dB is offline
Old 12-22-2014, 01:21 PM
Derf00
Gentleman's Relish
Derf00's Avatar
That only applied to the 05/06 model years. 07+ Ford fixed the problem. For 05/06 you could use moleskin or use the updated part number for the window molding.
Derf00 is offline
xdef00
02-27-2004 03:18 AM
Quick Reply: wtf is this
