Compass Mirror install
I'm going to replace it with an aftermarket/other OEM mirror with a screen in it to get a backup camera and homelink.
My point is I won't bother with the 07 mirror. Maybe one from a later model has more than a compass and that might be a route.
Not sure where the outside temp sensor is located, but installing it and routing wires could be a chore.
Completely different vehicle but, I installed a Gentex auto dimming compass/temp mirror (from a Chevy truck I believe) in my old '94 F250 several years ago. I would assume the Ford mirror would be similar, but it literally required 3 wires to wire up and function (out of the 16 that were on the pigtail). 12V switched power, ground, and the wire from the temperature sensor. The compass was built into the mirror.
I was able to tap off the fuse panel in the truck, and the temperature sensor I was able to run the wire for underneath the weatherstripping on the door and tuck underneath the fiberglass visor on the cab. On a Mustang I'm sure you could find some easy place to put it like inside the fender.
If you can get a (non-OnStar) mirror with pigtail, and temperature sensor you could likely do the same thing, if you do want compass and temp and the Ford one doesn't have it. Otherwise, I'm sure you could find online how to retrofit the Ford one.
Back in 06 I did this "Just ordered a Mazda dimming mirror # 0000-8C-G14A; Homelink, compass and temp from worldpartsexpress.com for 237.90, 17.84 shipping and 2.00 handling, ttl 257.74. Can't wait to get and install it." I don't think worldpartsexpress exists any more or could be changed.
lenko
Check my post # 68 here. http://themustangsource.com/forums/f...437549/index4/
Check entire thread.
lenko
I have a 2007 GT Premium Coupe wth the auto-dimming mirror w/ compass. I dont' like the auto-dim ! It doesn't dim noticeably. I bought this car new in June of 2007 and it's never worked to suit me. Does anyone know of a way to adjust the sensor or replace with a manual dim (yea, I know I'm crazy) ? Does anyone make a mirror with manual dim and a compass ? THX.
