Last edit by: IB Advertising
Browse all: Ford Mustang Powertrain Guides
- Ford Mustang V6 2005-2014: Why is My Car Leaking Oil?
Guide to diagnose trouble and recommended solutions.
oil Leak after an oil change at dealership
hi guys! I am new to the forum, this is my first post. Had my 2005 V6 oil changed at the dealership last friday. But yesterday, as the car was parked, I noticed the oil leak beneath it. I am wondering if this could be related to the oil change. they might have over filled it perhaps? I went down there to look, but it seems the leak is not coming from the drain plug or oil filter. Its coming somewhere from the engine block.
I had some drops on the ground after an oil change years back but what happened was they didn't wipe down the a arm/suspension stuff because it dripped from there. It could be somethinf minor like that instead of a main seal leak. How is the reading on the dipstick?
Update:
I brought it back to the service department of the dealership, thinking it could be related from the oil change. When I got there, I popped the hood and took a quick look and saw the coolant reservoir to be low. I thought about water pump. Then the mechanic took a look, and it was confirmed, they found out that my water pump was leaking. They topped it off, I asked for an estimate on water pump replacement and went home. When I got home, I tried to check the leak again, but it seems it went away. No more leak. Is that possible?
Update:
It is probably just the plastic thermostat housing - and it gets mis-diagnosed as a water pump issue because the fluid runs from that housing down the water pump. Most of it goes under your intake manifold because the split typically happens on the back. Look at the back of the housing and under the manifold and there is probably fluid in the valley back there.
soulcaliber39
12-28-2016 04:57 AM
