Sponsored by:
Sponsored by:
Poor Engine Performance
Old 04-30-2015, 08:12 AM
cruisin5268d
cruisin5268d's Avatar
Originally Posted by MIKE562
I didnt know you were the thread police
You never asked.
Seriously though, I think everyone on a forum should be empowered to give a little nudge to someone when they create duplicate threads across the site.
cruisin5268d is offline
Old 04-30-2015, 01:45 PM
Nuke
Nuke's Avatar
Before anything else, I'd reclean the TB and I'd disconnect the battery for 30 minutes to reset the Adaptive Learning on the PCM. This often helps restore from a lot of granny/city driving settings. Also, after a reset, you may notice some rough engine operation the first few dozen miles.
Nuke is offline
Old 04-30-2015, 01:48 PM
Nuke
Nuke's Avatar
Isn't this a duplicate of your post in the S197 main forum?
Nuke is offline
Old 04-30-2015, 06:02 PM
CMcNam
CMcNam's Avatar
Surprise!
Originally Posted by cruisin5268d
You never asked.
Nudge, push, trip, kick, whatever. I don't think there's a rule against it.
CMcNam is offline
Old 04-30-2015, 06:38 PM
MIKE562
MIKE562's Avatar
No its just an illusion
MIKE562 is offline
Old 04-30-2015, 06:55 PM
Moderator
JimC's Avatar
Cruisin might not be the "thread police" but..........
Please don't start multiple threads on the same thing. No need to clutter the board.
Threads merged.
JimC is offline
Old 04-30-2015, 07:44 PM
MIKE562
MIKE562's Avatar
Thank you
MIKE562 is offline
Old 05-01-2015, 12:10 PM
Nuke
Nuke's Avatar
Any update on your issue (the car, not the duplicate threads. 😛 &#128526?
Nuke is offline
Old 05-01-2015, 11:49 PM
MIKE562
MIKE562's Avatar
I haven't had much time to check the spark plugs or the COP's. I will get to them by the the end of this weekend (I need a to get me a torque wrench!). I did check the fuel injectors to make sure they're all firing, which they are. I've also checked for vacuum leaks and have not found any so far.
I just bought a can of Seafoam, but I'm not sure how I feel about feeding it through the vacuum lines, so I'm going to pour it in the gas tank instead.
I will post an update once I pour Seafoam and check spark plugs/COP's
MIKE562 is offline
Old 05-02-2015, 07:33 AM
Nuke
Nuke's Avatar
Regarding the SeaFoam, you'll need to ensure the ratio is appropriate and then run that mix until you're down to about 1/4 tank to get the most benefit. sometimes it takes a 2nd attempt if it's a stubborn, fuel system-related problem.
Nuke is offline
djbigskrilla
09-20-2022 01:04 AM
Calizic
08-28-2015 01:46 PM
inyadreems
08-21-2015 09:10 AM
Pain.
08-07-2015 10:48 PM
Quick Reply: Poor Engine Performance
