Need HELP please! 2010 brake lights won't turn off
This afternoon I noticed my brake lights (and 3rd brake light) were on although the car was off and had been for a few hours. Thinking maybe something was stuck I drove it around the block and hit the brakes a little harder than normal. They were still on. I checked the switch on the pedal (blue & white) and it looked ok. I disconnected it, checked the lights, still on! The spring on the switch seemed to work fine.
Frustrated I disconnected the battery, let it sit for 30 or so mins, and as soon as I reconnected it, lights back on!!
What can this be?? Any insight would be great.
thank you in advance.
-Kristen
-Kristen
-Kristen
-Kristen
That means if the switch were at fault, ALL the brake lights would be on, not just the third one.
Most likely a short somewhere in the wires of the third brake light.
Open the trunk while the light is on to see if it goes out. If it does, then short is in the wiring that goes around the Trunk Hinge, if the light stays on, take the black cover off the inner trunk lid and inspect the light third brake assembly for any obvious burn signs. Burn signs are indicative of a short. If that doesn't pan out, now you have to trace the wire back to find out where it's getting shorted.
bond007
08-26-2015 11:36 PM
KEM Motorworks
08-14-2015 10:13 PM
