Sponsored by:
Sponsored by:
Resurfaced Rotors But Still No Good?
Old 11-07-2015, 01:26 PM
winner99
winner99's Avatar
Angry Resurfaced Rotors But Still No Good?
I did front brakes at 50k miles on my 2012 GT because the rotors were jumping, pads still had about 40% left on them. After I had them resurfaced I still noticed some uneven feeling at like 5mph, barely nothing compared to before. At high speeds say hard braking at 80mph it was pretty noticeable still. Now it has gotten worse 4 weeks later to the point they were at before I had them cut which took 50k miles to get to.
Can I assume that any heat spots went to deep into the rotor for them to be cut out? I don't want to have to keep taking them off to cut more life off of them. Maybe the shop didn't take enough off?
I have z26 powerstop pads on now. Not sure if that will make a bigger difference with the stock rotors.
winner99 is offline
Old 11-07-2015, 06:03 PM
Stangbass
Stangbass's Avatar
If you can feel the unevenness of a rotor at 5 mph the rotor is toast. No amount of turning is going to bring it back true without making it dangerously thin. The rotors need to be replaced as well as the pads.
Stangbass is offline
Old 11-07-2015, 07:54 PM
Simon1
Simon1's Avatar
You cannot turn heat spots out of a rotor. Get a different pad, new rotor and flush some fluid and you will be good.
If you have hot spots, which area usually bluish, then you will get them again unless you change something. New pads usually fix it.
If you were to put on some better rotors and pads and did not go to the track road racing, they would probably last 30-50k.
Simon1 is offline
Old 11-07-2015, 07:58 PM
Chromeshadow
Chromeshadow's Avatar
Ford has a little history with warped rotors, there are a few things I always avoid: Tightening the lugs with an impact wrench, I only use a torque wrench.
I also make sure I have the emergency brake off, and my foot only lightly on the brake pedal when I start my 2012. I believe when a car is not moving, and you start the engine with your foot on the brake pedal, the brake hydraulic pressure increases suddenly, and forces the brake pads into the rotors. Over time, I believe this may cause them to warp. I've never had a warped rotor.
Chromeshadow is offline
Old 11-08-2015, 05:17 AM
Dino Dino Bambino
Dino Dino Bambino's Avatar
Agree 100%
That's a wise policy. Overtightening of the lug nuts with an impact wrench can indeed warp the rotors so beware next time you visit a tire shop.
Dino Dino Bambino is offline
Gun Jam
11-10-2015 06:30 AM
Silverblade
11-05-2015 09:50 PM
11-04-2015 03:41 PM
snafu7x7
10-29-2015 09:28 AM
Rob@Evolution
10-14-2015 11:20 AM
Quick Reply: Resurfaced Rotors But Still No Good?
