Sponsored by:
Sponsored by:
Coolant leak in my 2012
Old 11-24-2015, 01:37 PM
Panthermom
Panthermom's Avatar
Default Coolant leak in my 2012
Friday I went out to a large puddle of coolant under my car. The reservoir was 1/2 empty. I took it to the shop where they pressure tested it and could not find a leak anywhere. It hasn't leaked since. Does anyone have any ideas of what it might've been?
Panthermom is offline
Old 11-24-2015, 05:16 PM
Panthermom
Panthermom's Avatar
Spoke too soon. It did it again. It's leaking down behind the pulleys but I can't get a good look at the place of origin. Water pump?
Old 11-24-2015, 05:29 PM
bfunke
bfunke's Avatar
What engine do you have. The 4.0L V6 has known problem with the plastic thermostat housings cracking and causing coolant to leak and drip down the front of the engine.
bfunke is offline
Old 11-24-2015, 05:37 PM
Panthermom
Panthermom's Avatar
3.7L V6. I'll have them check that just in case. Is it a noticeable crack if they take it out look at it?
Old 11-24-2015, 07:08 PM
Moderator
JimC's Avatar
The 3.7 has had an issue with a small hose that comes off the pump. Originally it didn't have a check valve in it, but starting in 2013 (I think) Ford changed the hose.
Completely different issue from the 4.0 plastic thermostat housing.
JimC is offline
Old 11-24-2015, 08:11 PM
Panthermom
Panthermom's Avatar
Thank you both. Whatever it is, is only happening when I've been driving a while. My 10 minute jaunts to Walmart don't affect it. Taking her to the shop first thing. I just hope they can fix whatever it is, in one day. (With the holidays and all)
Old 11-25-2015, 11:50 AM
Panthermom
Panthermom's Avatar
Water pump, o-rings and a hose. $411 plus tax. Merry Christmas to me. They had to order parts. Won't be in till Friday. Joy
Old 11-25-2015, 05:52 PM
Art161
Art161's Avatar
How many miles on the car? I think this repair is covered by the five year or 60,000 miles Engine warranty.
Art161 is offline
Old 11-25-2015, 06:05 PM
Panthermom
Panthermom's Avatar
30,000 checked with the dealership and with Ford and they both said "no." Ford did tell me to keep my receipt though in case there's ever a recall on the water pump I can get reimbursed.
Old 11-25-2015, 09:16 PM
Art161
Art161's Avatar
Hmm. I guess Ford changed its warranty. The warranty booklet for my 2007 specifically mentions the water pump as being covered 5/60.
Edit: I did a Google search for the 2012 Ford Mustang warranty, and it says the water pump IS covered. On what grounds is Ford denying coverage?
https://www.ford.com/resources/ford/...12Warranty.pdf
Check out page 10.
Art161 is offline
Boostaddict
Lethal Performance
11-27-2015 03:32 PM
Urambo Tauro
11-24-2015 10:26 AM
Granatelli Sales
11-20-2015 05:28 PM
Tribefan
Carolina Regional Chapter
20
11-11-2015 11:02 AM
tlgtre
10-31-2015 05:48 PM
Quick Reply: Coolant leak in my 2012
