Sponsored by:
Sponsored by:
*Help* Noise above 25mph
Old 07-10-2016, 05:47 PM
Mach1BBFun
Mach1BBFun's Avatar
Default *Help* Noise above 25mph
Please view video:
https://youtu.be/d6CNZ9qCWxU
Car: 05 mustang GT
Noise starts at 25mph and does not go away. Sounds like a helicopter chasing me in the car. No vibration, just noise.
Parts replaced after noise started:
Driveshaft
Axle Bearings
Rear gears
Rear Diff Unit + bearing kit
Brake pads/Rotors
anyone with experience have a clue??
Mach1BBFun is offline
Old 07-10-2016, 07:20 PM
Stangbass
Stangbass's Avatar
Sounds like a bad front hub/bearing assembly, possibly a tire.
Stangbass is offline
Old 07-10-2016, 08:30 PM
Mach1BBFun
Mach1BBFun's Avatar
Have put 1 new hub on the right front but not the left. Reason I have ruled that out is because it sounds like it's coming from the rear.
All 4 tires are new as well
+ front wheels have no play
+ had bad wheel bearings before in front of other cars. You can't hear this reflecting off curbs/other cars like I could when I've had bad wheel bearings in the past
Old 07-13-2016, 08:31 PM
Mach1BBFun
Mach1BBFun's Avatar
Any ideas?
Old 07-13-2016, 09:49 PM
Eleanorspeedster
Eleanorspeedster's Avatar
probably need to hear the sound
Eleanorspeedster is offline
Old 07-14-2016, 06:43 AM
Coosawjack
Coosawjack's Avatar
A Wump.....Wump.....Wump sound that increases in frequency with increased speed is normally a rear wheel bearing and axle!!
FORD 8.8" rears are famous for it...especially the right side ones!!
Coosawjack is offline
Old 07-14-2016, 11:03 AM
Mach1BBFun
Mach1BBFun's Avatar
It does the above. Replaced axle bearings but not axles. Honestly believe it could be an axle shaft?
Old 07-14-2016, 11:26 AM
Coosawjack
Coosawjack's Avatar
You should always replace both since the bearing runs on the axle surface and in time wears a groove in the axle...see photo!!
I tried to find a photo of my '04 Marauder axles at 177K miles.....had about a 1/8 inch groove where the bearing runs......Wump.....Wump.....Wump....BAD!!:icon_cry :
Good Luck!!
Old 07-14-2016, 07:41 PM
Mach1BBFun
Mach1BBFun's Avatar
Not that I don't trust the above, but anyone else have ideas before I go drop $400 on axles?
Old 07-21-2016, 06:10 PM
Laguna02Stang
Laguna02Stang's Avatar
Does a 2002 gt have an 8.8 rear?
Laguna02Stang is offline
Quick Reply: *Help* Noise above 25mph
