Power Seat Switch
Power Seat Switch
So the power seat in my 2005 Mustang won't move forward. All other directions work fine. I pulled the seat out of the car in hopes of finding the issue. There were a lot of other posts for things to check, but I didn't find what I need...
When I pulled the seat out, I disconnected the connector that goes to the little motors. Then I ran 12v directly to the pin for the front/back motor, and it works fine in both directions. Then, when I hook it all back up, it still doesn't work. I'm thinking it's the switch, but I'd rather not spend $100+ on a guess. Any thoughts? I pulled the switch, and I opened it up, and I tried testing the resistance between the pins, but I couldn't find anything obviously wrong...
Any help would be much appreciated.
Rick
Rick
Looks like this is a common issue (at least common enough that others are having it and posting it around the internet). One of the three little micro switches inside the seat switch went bad. It is most common to the switch that moves the seat forward. Anyway, $120 for a new switch, and 1/2 hour of time and I had it swapped out. Works like new.
