Sponsored by:
Sponsored by:
anyone install steeda pullies, need help please!
Old 02-10-2006, 07:49 PM
stangxs
stangxs's Avatar
Default anyone install steeda pullies, need help please!
installed the pullied, turned on the car, and the water pump pulley is scraping on an alternator bolt... what am I supposed to do?
stangxs is offline
Old 02-10-2006, 09:39 PM
Daniel60
Daniel60's Avatar
Default RE: anyone install steeda pullies, need help please!
the same thing happen to mine yesterday. They sawed off the bolt somewhat so the pully would not hit it.
Daniel60 is offline
Old 02-10-2006, 09:47 PM
Daniel60
Daniel60's Avatar
One thing I like to add is that tonight while driving to a restraunt and back I noticed my pullys were whistling. Does anyone know what that means? The performance is still there I just don't like noises.
Daniel60 is offline
Old 02-11-2006, 01:56 AM
hawgman
I ♥ Acer
hawgman's Avatar
The Steeda pulley set is supposed to come with a new bolt for the alternator bracket. If you did not have one in your kit, then it was incomplete.
hawgman is offline
Old 02-11-2006, 10:16 PM
LarryS
LarryS's Avatar
ORIGINAL: Daniel60
Does your water pump pulley have big holes in it? That is probably the source of the whistling. Best to buy the brands without holds. ASP water pump and crank do not have holes for this reason.
LarryS is offline
Old 02-11-2006, 11:47 PM
1SIKPONY
1SIKPONY's Avatar
what is the whole kit supposed to have? mine just got delivered yesterday and all it has is one thing that looks like a pullie, another thing that has the round shape of a pullie and has 4 or 5 holes in it, and 3 bolts i think? does anyone have a pic? please!!!!!
1SIKPONY is offline
Old 02-11-2006, 11:58 PM
hawgman
I ♥ Acer
hawgman's Avatar
If you ordered a Steeda kit, you should have a new water pump pulley which looks like a metal "bowl" with 5 holes in it. 4 bolt holes and a center hole to go over the water pump shaft. A crank pulley. A new alternator bracket bolt, a crank pulley replacement bolt, and a crank pulley pull down bolt ( will be longer than the replacement bolt ).
If you have a different brand it may have different contents.
hawgman is offline
Old 02-12-2006, 12:00 AM
FrdMstnggt99
FrdMstnggt99's Avatar
The kit comes with a "guide" bolt to help the new crank pulley onto the crankshaft keyway. Then you are supposed to use the factory crank bolt to hold the Balancer on. There is a smaller bolt, about a 12mm head, that is suppose to replace the lower-right alternator bracket stud. Look for this bolt and use it!
FrdMstnggt99 is offline
Old 02-12-2006, 12:08 AM
hawgman
I ♥ Acer
hawgman's Avatar
ORIGINAL: FrdMstnggt99
Hummm.. Mine actually came with a new crank bolt, along with the "guide" bolt that was 1/2" or so longer.
hawgman is offline
Old 02-12-2006, 12:55 AM
SpikeGT
SpikeGT's Avatar
I just recieved my Steeda Udp kit last week. My kit has Crankshaft balancer pulley,water pump pulley, 1 bolt for installation only, and two more bolts.
So 5 pieces all together.
[IMG]local://upfiles/13448/417ED84BCF804453ACF793EEB2FAE487.jpg[/IMG]
the one in middle is installation bolt, one is new alternator bracket bolt, and the other is ?
SpikeGT is offline
Quick Reply: anyone install steeda pullies, need help please!
