2010 V6 Trual Dual Exhaust Questions!! Can someone help me with this?
#21
Here is the Difference between the Shorter 2008 VS the longer 2010
And this is how much my my tip is out which to me is perfect, one of the few things I did not like about the rear was how far the tip stuck out. Ford should have put the tip on to match the angle of the car IMO.
#22
#23
#24
i wasnt even planning on selling them i was just gonna keeep them just in case i ever decided to get rid of my car, but when i seen you were looking for some i figured i would help you out. if you change your mind let me know
#25
Thank you for the offer, I really appreciate it. I'll let you know.
#27
http://www.partswebsite.com/fordpart...n=7&type=parts
#29
Siber Express, Thanks for posting those pics comparing the 2 mufflers, Im sure it will help others out!
Base on your picture of how you like it, did you intentionally cut the pipes shorter to get the look you wanted? mine stick out similar to how it looked when stock.
The only problem I have found with the mufflers sticking out and the design of the rear bumper, is that once (thats all it took) when at the gas station filling up I backed into the exhaust pipe when wearing shorts and not paying attention, lets just say it got my FULL ATTENTION
#30
I do know the GT500 Rear Valance has about 1 more inch of Plastic to the rear on the bottom so some is hiding behind it and when we did the exhaust on my friends 05 the over the axle pipe was about 1 inch back from the Y-Pipe in the clamp, so if mine was like that (it is all the way up to the X-Pipe now) it could make up some of it also.
And yes, backing into that would definitely get your Full Attention.
Galactic
04-29-2019 02:56 PM
maxshuty
31
05-27-2009 12:24 AM
