How do you know if your convertible top is vinyl or cloth?
Old 04-20-2015, 08:18 AM
Ron750
Ron750's Avatar
Default How do you know if your convertible top is vinyl or cloth?
I want to use a Ragg Topp protectorant on my 2012 Mustang, that I bought in February. The Window sticker says the top is vinyl, but water doesn't bead up on it. Is there an easy way to make sure it is vinyl?
This is how it looked right after putting water on it.
Ron750 is offline
Old 04-20-2015, 09:55 PM
cruisin5268d
cruisin5268d's Avatar
I'm not sure how to answer that. Vinyl is, well, vinyl. Fabric is like a fabric.
cruisin5268d is offline
Old 04-21-2015, 05:00 AM
Ron750
Ron750's Avatar
Most products that are made of vinyl are flat. This has texture similar to fabric. I am pretty sure they are hundreds of thousands of tiny extrusions. My window sticker says it's vinyl, so I am sure it is, but I would like to know a definitive test before putting protectorant on it.
Ron750 is offline
Old 04-21-2015, 07:03 AM
PNYXPRESS
PNYXPRESS's Avatar
You should be able to feel the difference.
If the window sticker says vinyl then it should be safe to assume its vinyl, unless you have a reason to believe it was replaced.
PNYXPRESS is offline
Old 04-21-2015, 06:56 PM
Ron750
Ron750's Avatar
I saw an older Mustang convertible for sale. It had a cloth top, and the difference was obvious. It looked like cloth!
Looking forward to washing and treating my vinyl if Winter ever ends.
Ron750 is offline
Old 05-01-2015, 03:06 PM
chrisdbassplayer
chrisdbassplayer's Avatar
I have had a vinyl top convertible and now own a cloth top convertible. from the small picture you provided it looks to be vinyl.
chrisdbassplayer is offline
Old 05-01-2015, 07:39 PM
1985GTto2013GTCSV
1985GTto2013GTCSV's Avatar
I believe in 2013 the standard is vinyl and at least the GT Premium package bumps it to cloth. Either way if its cloth it would show in the sticker as an option even of part of a package... plus that looks like vinyl. If you had cloth, you wouldn't wonder.
1985GTto2013GTCSV is offline
Old 05-01-2015, 10:51 PM
xkape
xkape's Avatar
going to sound odd but, if you run your fingers across it real fast and it makes that sound that's kinda like scratching a record, its vinyl
xkape is offline
Old 05-04-2015, 07:38 AM
Ron750
Ron750's Avatar
I cleaned and treated my wife's top with Ragg Topp. Used the horsehair brush that came with the kit, and it worked well. The top went from Brown to Black which you can see in the picture below. Overspray came off easily with a microfiber.
Ron750 is offline
b8checker
09-30-2015 07:11 AM
treesloth
09-28-2015 07:03 AM
LivingInThePast
09-16-2015 12:20 PM
Oak
09-14-2015 03:08 PM
Quick Reply: How do you know if your convertible top is vinyl or cloth?
