3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
3.7 v6 no mufflers = awsome...
Old 01-16-2013, 11:49 AM
2k232
2k232's Avatar
Default 3.7 v6 no mufflers = awsome...
Just had my stock mufflers removed running all stock with straight pipe replacing the muffler/reusing stock tips. And wow in my opinion this is a really good setup. It's really not loud for day to day driving. 2.5k on up it screams.... Tue YouTube videos really don't do it justice....
2k232 is offline
Old 01-17-2013, 06:32 PM
schram1
schram1's Avatar
good weight reduction to
schram1 is offline
Old 01-17-2013, 07:07 PM
2k232
2k232's Avatar
Oh yea def at least 40+ pounds
2k232 is offline
Old 01-17-2013, 08:28 PM
2009 Eleanor
2009 Eleanor's Avatar
put up a sound clip!
I'd like to hear it!
2009 Eleanor is offline
Old 01-17-2013, 08:55 PM
2k232
2k232's Avatar
I'll try to do one tomm currently wet/rainy outside.
2k232 is offline
Old 01-25-2013, 11:58 PM
2011Kona3.7L
2011Kona3.7L's Avatar
I took mine off a couple of years ago just for kicks. Went from the Little Rock area up to Fayetteville - through the Bobby Hopper Tunnel on I-540. To paraphrase Jeremy Clarkson, it sounded like it was full of demons.
2011Kona3.7L is offline
Old 01-26-2013, 08:31 AM
157dB
Cut & Paste Expert
157dB's Avatar
I ran sans mufflers but it got old really quick.
I also did the bobby hopper trick, it was a blast.
Had to do it a couple of times just because it was fun...
157dB is offline
Old 02-20-2013, 08:51 PM
Katmandu
Katmandu's Avatar
Question
Is it still raining where you at ?
Post up a video of your exhaust sound for us to hear !
Katmandu is offline
Old 02-20-2013, 11:51 PM
hogasswild
hogasswild's Avatar
Stock mufflers and tips weigh 46lbs alone. I put in pypes mufflers instead and easily shaved 26-28lbs off.
hogasswild is offline
Old 02-21-2013, 02:32 PM
WORKISSLOW
WORKISSLOW's Avatar
I took the OE muffler weights off and weighed them, they were 28oz each, that is 3.5lbs right there. The only time I notice any additional vibration is occasionally at idle.
I noticed that Roackauto sell the Dynomax 2.5" Cat-back tubes for around $44 each, I am thinking of buying those and then running the Pypes Mufflers. That ought to shave 25lbs off and flow more exhaust. That or buy the dynomax Cat-back kit and maybe swap out the mufflers later.
WORKISSLOW is offline
OlPal
58
04-14-2016 02:35 PM
SYNY5TER
03-22-2015 04:24 PM
2k232
01-07-2015 08:19 PM
2k232
01-05-2015 08:16 PM
LMPerformance
08-09-2010 01:46 PM
Quick Reply: 3.7 v6 no mufflers = awsome...
