3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Water Sloshing Around INSIDE Driver's Door?!
Old 07-20-2013, 09:28 AM
The Ders
The Ders's Avatar
Originally Posted by WindyMustang
Good thread! I haven't run into this yet...of course, I've only had to turn the wipers on once...
Wanna trade??? Mine have been on every day for the past week...
The Ders is offline
Old 07-20-2013, 11:48 AM
WindyMustang
WindyMustang's Avatar
Nah, I'm good.
WindyMustang is offline
Old 07-20-2013, 11:52 AM
jwkim524
jwkim524's Avatar
i checked mine and yup it was clogged
jwkim524 is offline
Old 07-20-2013, 03:40 PM
Nuke
Nuke's Avatar
The 05 thru 10 have 2 drain holes per door with black plastic plugs in them. A lot of people remove the plugs since they just make the drain holes clog faster. Your '12 MUST have some sort of drain holes.
Nuke is offline
Old 06-15-2015, 05:33 PM
Debchevy2
Debchevy2's Avatar
Post rain in doors of 2007 Mustang
You guys are a lifesaver! After a week of rain, I noticed there was water sloshing in my doors on my way to work. After removing the door drains and clearing out the drains, a quart of water must have poured out of my doors. It started raining again as I was doing this, and we have predictions for another week of rain, so I'm glad I quickly found a solution. Thanks!
Debchevy2 is offline
Old 06-15-2015, 07:14 PM
99GTvert
is my username.
99GTvert's Avatar
Glad to help...cuz now I have a '12 too lol. I don't hear the water sloshing on mine so far. Haven't checked the drains to see if they're free and clear though.
99GTvert is offline
Old 01-08-2017, 10:58 AM
cjzryd
cjzryd's Avatar
Thanks for info! I had my car oil sprayed a bit back, noticed the last two car washes I had sloshing in the door. Water ran out when parked nose down. Following your suggestion I removed drain plugs. Rear drain plug was packed full of debris and oil spray. Now all good in that department, but... should I actually be getting that much water in my door in the first place?
cjzryd is offline
Old 01-09-2017, 06:54 AM
The Ders
The Ders's Avatar
I've had it happen with 2 of my 3 that I've owned. It seems to be a hit and miss thing in my personal experience. And the main times I've noticed it happen with them is after very heavy rainfall for multiple days or if I washed the car more than normal. I would imagine that the window trim/weathering(?) would be a potential cause but I recall talking to someone when it initially happened with mine and they said that replacing it probably won't prevent it from happening again. I just fully removed those plugs from my doors and never had an issue since. But again it seems to be a hit and miss thing, more common than you'd think.
The Ders is offline
Old 01-09-2017, 07:57 AM
pascal
S197 Section Modder-ator
pascal's Avatar
......................but... should I actually be getting that much water in my door in the first place?
If water cannot evacuate due to drain plugs being clogged, absolutely!
Water will accumulate inside the door and rise until it escapes from behind your door panel and then dump on your floor board.
I have seen this on brand new cars at the dealer lot. lol
Now if you were wondering whether or not you get water inside the door in the first place it's a certainty, as there are no cars made on the planet that have water proof doors.
Water gets in there by the window felt for the most part and it's OK, as long as water can drain out.
pascal is offline
Old 06-12-2017, 08:04 PM
Bob_T442
Bob_T442's Avatar
I've got the sloshing now, too, on my '12 V6 ragtop. I'm forum surfing to try to pinpoint sources, it sounded like door(s) full, sometimes quarter(s), I was also wondering about HVAC intake plenum not draining. Lotsa rain in SWFL lately, I'll start pulling things apart and update the forum on findings.
Bob_T442 is offline
Quick Reply: Water Sloshing Around INSIDE Driver's Door?!
