3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Had LCA's replaced but problem resulted . . .
Old 05-20-2014, 05:16 PM
GTC
GTC's Avatar
Default Had LCA's replaced but problem resulted . . .
Under a Ford TSB 12-8-24 I had the LCA's replaced on my 2013 Mustang Premium, and when it was put back together the steering wheel was off-center and the dealership is baffled. Said they've done many before with no problem.
Any experience with this out there?
I should mention that everything is fine as far as alignment.
GTC is offline
Old 05-22-2014, 10:06 AM
Mike1Six
Mike1Six's Avatar
Your car is not in alignment. I had the same issue with the steering wheel being off center. It constantly pointed to 1 o'clock while driving straight.
If the dealer is baffled then I would seriously question the dealers ability to work my car.
Take it to something like Kaufman tire and they can resolve it for you. At least, they did for me.
Found this in another post...
"I noticed you have rear lower control arms. This may cause a thrust angle in your rear axle which will allow the car to drive straight, but the steering wheel will be off slightly. I experienced this firsthand, and I replaced my solid rear LCAs with UMI adjustables. My car tracks perfectly straight now."
http://www.allfordmustangs.com/forum...out-there.html
Mike1Six is offline
Old 05-22-2014, 11:18 AM
mustlemn
mustlemn's Avatar
I have had similar problems with few dealers' service departments Mike1Six.
Sometimes they give big promises and can't deliver.
GTC I would check the alignment again.
mustlemn is offline
Old 05-22-2014, 09:40 PM
GTC
GTC's Avatar
Picked it up and it was fixed. Tracks,perfectly.
GTC is offline
djbigskrilla
09-20-2022 01:04 AM
cyclop5
10-03-2015 09:21 PM
Hogquad
08-23-2015 05:26 AM
dseg
AmericanMuscle.com
08-10-2015 03:29 PM
JonnyBlazeGT
08-09-2015 10:19 AM
Quick Reply: Had LCA's replaced but problem resulted . . .
