3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Upgraded Fuel Pumps??
Old 11-12-2014, 06:28 PM
V6ProCharge
V6ProCharge's Avatar
Exclamation Upgraded Fuel Pumps??
I have a 2012 V6 recently installed a D-1SC Procharger and want to push 12lb @~6500ft due to this I have gotten new fuel injectors to deal with the increased fuel flow but I need a new fuel pump also. Anyone know where I can get a upgraded one that will fit all the stock connections and hook ups? Until then I'm running 8lb but really want to be at 12! Any ideas?
V6ProCharge is offline
Old 11-12-2014, 07:02 PM
Siber Express
Siber Express's Avatar
BBK has one that puts out 300 LPH
http://www.americanmuscle.com/bbk-fu...0lph-10gt.html
I am not sure but I do believe the GT500 pumps will fit also.
Siber Express is offline
Old 11-12-2014, 08:06 PM
V6ProCharge
I had ordered a GT500 Pump hoping that it would work but the connections do not match up.. It was a close fit but not quite and I'm not trying to modify my entire fuel system just yet. I'll give a look at the BBK one thanks!
Old 11-29-2014, 08:25 AM
runninpony6
runninpony6's Avatar
I'm running about 10lbs during the colder months. I'm using an JMS fuel booster. The car seems to like it just fine. It increases the voltage to you pump by using a Hobbs switch, this is regulated by the amount of boost you making at that time
runninpony6 is offline
Old 11-29-2014, 08:27 AM
runninpony6
Side note:
Are you having any issues with oil blow by on the drivers side into the inlet pipe of the air intake?
10-26-2015 05:01 PM
Meystang
09-25-2015 04:05 PM
pimp2303
09-17-2015 08:45 PM
SteelerNation82
09-16-2015 07:11 AM
rksnow1
09-14-2015 08:46 PM
Quick Reply: Upgraded Fuel Pumps??
