3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Loosing coolant 2011 3.7
Old 03-28-2015, 06:06 AM
Icman69
Icman69's Avatar
Default Loosing coolant 2011 3.7
I have been randomly loosing coolant about a quart every two weeks never a raise in engine temp no indication of any leaks at water pump or thermostat housing. it leaves a small bit of coolant perhaps once a month under the car on the floor but not level ground so can't really pin point it. Car has 65K on it daily driver. Any Ideas?
Icman69 is offline
Old 03-28-2015, 07:30 AM
99GTvert
is my username.
99GTvert's Avatar
My 99 leaves a bit on the ground up front by the radiator drain plug because of a small crack above the drain. Can you get under your car to look? If you change your own oil do you see anything unusual when it drains in case there's a head gasket issue?
99GTvert is offline
Old 03-29-2015, 07:36 AM
Icman69
Icman69's Avatar
I don't do my oil and car is way too low to the ground to get under. I have started to put news paper under it to try to see where it is. I suspect a leaking heater core sometimes in warm weather the windshield will fog a bit when the windows are down and no heat or ac. I am more than likely going to just take it to the local ford dealer let them figure it out. I have an extended warranty that will cover it.
Icman69 is offline
Old 03-29-2015, 10:47 PM
cruisin5268d
cruisin5268d's Avatar
Take it to the dealer. hat should still be under warranty, yes?
cruisin5268d is offline
Old 04-01-2015, 08:00 PM
jeremy813
jeremy813's Avatar
They all do that. Mine just got back from the dealer with 24K miles...
REFERRED TO TSB 14-0212, REPLACED WATER PUMP, SEALS, AND THERM HOUSING TO DEGAS HOSE RECHECK AND VERIFIED AS PER TSB 14-0212
jeremy813 is offline
Old 05-15-2015, 02:50 AM
Icman69
Icman69's Avatar
Jeremy
Thanks for the info that fixed it right up.
Icman69 is offline
Old 05-18-2015, 01:21 AM
streetshark 5.0
streetshark 5.0's Avatar
Thank you that answer why mine has leaked slowly , my 2011 mustang gt has 26,000 miles and my delivery date is 11/01/2010 . so the 5yr /60,000 powertrain warranty should cover it right???? thanks guy
streetshark 5.0 is offline
Old 05-18-2015, 08:36 AM
Icman69
Icman69's Avatar
As far as I am aware this TSB is for the V6 but I could be wrong. I would think it would be a warranty issue.
Icman69 is offline
Granatelli Sales
01-20-2020 12:34 AM
BeatnikFink
10-01-2015 08:00 PM
wraith777
09-28-2015 10:49 AM
Sixer4Life
09-28-2015 07:05 AM
MusicCity615
09-12-2015 07:05 AM
Quick Reply: Loosing coolant 2011 3.7
