351 Mustang
gt-40 on 351W ?
Old 01-13-2010, 11:13 AM
stangowner8687
stangowner8687's Avatar
Default gt-40 on 351W ?
ok im aware the 351 is wider but will the gt40intake upper and lower work? or will i need an intake from another? if so where? i have been looking on here for the past 20min and all i been getting is carb'd motors and TF intakes i would like to use the gt40
stangowner8687 is offline
Old 01-13-2010, 11:23 AM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
why do you want to use a GT40?
there's a reason people suggest the TF intakes or going carb...
sn95_331_GT_ yellow is offline
Old 01-13-2010, 11:41 AM
stangowner8687
to each their own... but i always liked the look of the tubular gt40 over edelbrok and TF i liked the BBk intakes but bbk informed me they will not work on 351W
Old 01-13-2010, 11:56 AM
stangowner8687
also reason being is im not looking for a 700hp 9sec drag car. this will be more of a street car with cornering in mind more like 450-500rwhp with the use of ported 185afr, 408 stroker. though i will rarely see 5k rpm its nice knowing ive got it when needed
Old 01-13-2010, 12:09 PM
cccharleston
cccharleston's Avatar
Those AFR 185s are not going to get you there. Build a 347.
cccharleston is offline
Old 01-13-2010, 04:31 PM
sn95_331_GT_ yellow
or just put them on a stock 351W shortblock...
BTW, the GT40 lower in discontinued from Ford and all the lightning/present owners know this. the lowers go for about as much as you can get a COMPLETE TFS R series for a 351W.
anyways, stock 351W (get a F4TE block so itll take a hyd roller) a mild cam, AFR 185's, and the R series should be a fun little ride and pull until 6000rpm. extra weight might nullify the power advantage, but at least itll last forever and a week...
youre gonna want to go past 5000rpm trust me. the truck engines go until 5500rpm anyways...
Old 01-13-2010, 05:37 PM
KNS1
KNS1's Avatar
I like the TF R series on my motor. 302 lower intake will not fit the 351 block.
KNS1 is offline
Old 01-16-2010, 02:37 AM
stangowner8687
so in other words no one knows if the gt40 lower would fit the 351w or a lower that would fit the block and gt40 upper? i've been eyeing craigs list in the sections of PA lancaster, york harrisburg and MD baltimore i have seen them come and go counless times in the range of 300-450. all i was simply asking is if it would fit. not trying to be rude but my build would include enough to get my hp goal i wasnt asking for a build simply if a specific intake would mate to my block
Old 01-16-2010, 07:56 AM
vristang
vristang's Avatar
There are 2 versions of the GT40 lower intake.
302
351w
The 351w is a taller deck height, thus has a wider lifter valley.
The 302 intake will NOT fit the 351w.
The 351w sized GT40 intake is often called a "Lightning" intake.
Keep in mind...
The GT40 style intakes will kill the increased displacement of a 351w.
Not the best intake you could use for a larger engine.
jason
vristang is offline
Old 01-16-2010, 08:00 AM
uedlose
uedlose's Avatar
the gt 40 lower is nothing more then a Cobra lower a Explorer lower.. But No the GT40 will not fit the 351W BUT yes there is a intake that will accept a GT40 upper that fits a 351W like said they came on lighting trucks so all you got to do is find one and then you will be set..
uedlose is offline
Quick Reply: gt-40 on 351W ?
