351 Mustang
Factory crank strength
Old 06-08-2011, 06:06 PM
Milton
Milton's Avatar
Default Factory crank strength
Does anyone know what a "safe" point is for an early 351 crank?
I have a 70's 351 (d2 casting) that I'm in the process of rebuilding, I'm expecting a little over 500hp.
The combination will be 351 ci, undecided aftermarket topend, v1 strim (2.95/6.87 pulley combination), mild rpm's around say 6-6.5k tops
Milton is offline
Old 06-08-2011, 08:34 PM
87Stallion
87Stallion's Avatar
If you are planning to make that much power I wouldnt skimp on the bottom end.
Good cranks aren't that pricey.
87Stallion is offline
Old 06-08-2011, 08:48 PM
Milton
Milton's Avatar
I didn't have any intentions on using the factory crank. I just figured I might as well ask and make sure I don't "waste" money.
I'm really just trying to keep my self talked out of a stroker build, these things have a tendency to go bigger then planned and over budget lol
Milton is offline
Old 06-09-2011, 08:42 AM
Venomantidote95
Venomantidote95's Avatar
talking yourself out of a stroker WTF lmao! you can get a good stroker kit for way less than a blower!
If you arent going to use the stock crank then this thread is pointless right? on the other hand a stock 351 can handle that blower with a 10 lb pulley!
Venomantidote95 is offline
Old 06-09-2011, 05:41 PM
Milton
Milton's Avatar
I already have the blower, its on the car now. I'm rebuilding a spare 351 I have and when its ready I will yank the stock motor and put the blower on the new engine.
Basically I wasn't planning on using the stock crank but figured I might as well ask and see if its strong enough. If I could save a bit of $$$ on a crank I would but don't want to build a ticking time bomb.
Milton is offline
Old 06-09-2011, 06:22 PM
Venomantidote95
Like i stated 10lbs your good! if you want more then you can get ready to hear the ticking lol!
Old 06-09-2011, 07:33 PM
uedlose
uedlose's Avatar
Seen guys run well into the 9s with a stock prepped crankshaft. the stock crank will laugh at 500 HP. I have seen lots of turbo guys way over 500 hp with the stock crank with a good balance job. keep the rpms in check and the tune on like said you will have no problems.
uedlose is offline
Old 06-10-2011, 08:20 PM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
just build a 540 with twins...
sn95_331_GT_ yellow is offline
svfetter
10-05-2015 11:39 AM
jrrhd73must
10-02-2015 09:17 PM
breaking
10-02-2015 01:27 PM
09-17-2015 07:57 PM
Quick Reply: Factory crank strength
