Plastic between our hoods and windshields?
Has anyone drilled or slotted this piece of plastic to allow engine compartment heat to escape over the top of our cars? Am I wrong in assuming cooler engine=more effecient=more HP=faster? I know this plastic piece covers our cabin air filters on the passenger side of our cars. Not all Engine heat would be extracted from below though....since hot air RISES! I wonder if this plastic piece could be strategically drilled/slotted to drop engine temps at all? It has holes drilled into it in the corners to allow water drainage, what would a few more holes/slots do if it dropped engine temps?
......Maybe some mathmetician can calculate what amount of RWHP a 1 degree drop in temperature could get us.
I was joking about the RWHP drop b.t.w. I realize it is completely dependent on you cars specific mods.
RE: Plastic between our hoods and windshields?
i think that same mathematician would probably end up recommending a heat-extracting hood[8D]
bet you'd see more results (if any big ones) with a hood than those plastic pieces
definately... there are some nice hoods that are heat-extracting. I'm pretty sure most are deisgned to pull hot air up and out, although a couple might go opposite as well if I'm not wrong...
jwog666
12-27-2021 08:09 PM
mrappe
09-26-2015 10:16 AM
