cluster swap for more than 120mph
Old 01-25-2009, 07:22 PM
mustangman02232
mustangman02232's Avatar
Originally Posted by maxshuty
If we have a better Drive Shaft in our cars then will we be fine at speeds 110+? Or do we need to upgrade other things aswell so the parts wont fail??
you will need Z rated tires, a 6 pt roll cage, 5 pt harness, upgraded drive shaft, fire suit, helmet, an a race track
https://mustangforums.com/forum/6-cy...read-this.html
mustangman02232 is offline
Old 01-25-2009, 07:32 PM
blackice05
blackice05's Avatar
There is a link in the stickies for the mycolor retrofit. The problem with all of these upgrades in the speedo will not read correctly. The dealer would have to reprogram it i think.
blackice05 is offline
Old 01-25-2009, 08:06 PM
fazm
fazm's Avatar
Speedo reads fine with the swap. i swaped in a gt cluster without reprogramming it and it reads fine.
fazm is offline
Old 01-25-2009, 08:10 PM
clintster77
clintster77's Avatar
Hence the comment about the Tx Mile .
Its not illegal to drive 300mph but it is dangerous.
It is illegal to drive 90mph on public roads.
It is dangerous to drive at all.
You need more than a 6 point roll cage to go over 300mph.
People die all the time walking through parking lots.
Everything is risk .
Driving fast is not illegal.
clintster77 is offline
Old 01-25-2009, 08:18 PM
clintster77
Your a life saver
I was allready thinking of trying to make my own speedo plate that read 240mph and see if I could use a tuner to set the tire diameter to read twice as fast so if I had the original plate on the speedo it would read 20mph when I am going 40mph. 50mph would then be 100mph and so on.I don't know if the perimeters will let you change it that much but I wanted to try.
Old 01-25-2009, 08:26 PM
Avalanch3
Avalanch3's Avatar
Well, can't a tune fix that? Can doug at bama change it so the speedo reads correctly?
If I were you I'd go with the Saleen cluster, looks most clean.
If I were you, I'd get some nice wide Z rated tires, alumn driveshaft, and a nice straight road with no bumps. After that I'm pretty sure there shouldn't be any major problems unless they're winds up to like 50 mph drafting your car off the road.. Also does your car have a spoiler delete?
Avalanch3 is offline
Old 01-25-2009, 09:05 PM
clintster77
Does your car have a spoiler delete?
the saleen seems hard to find and more expencive.
spoiler delete .No.. but aero tune will be a priority . I wont be using the stock spoiler.
Old 01-25-2009, 09:37 PM
Avalanch3
Avalanch3's Avatar
A larger spoiler would plant the rear firmer to the ground. The more aero, the better. Also lowering the car would be a good idea.
Old 01-25-2009, 09:56 PM
clintster77
I was going to also put on front spoilers more like a time attack car would be set up . I know this will lower my top speed but the trade off will be confidence in its handling at higher speeds. A nice diffuser in the rear is on my list also.
Old 01-25-2009, 10:07 PM
pascal
S197 Section Modder-ator
pascal's Avatar
I like having a limited speedo and watch the needle go past 120mph and go in the glove box!
pascal is offline
Quick Reply: cluster swap for more than 120mph
