ODBII P0108 on 2006 base
Old 11-13-2012, 10:45 AM
Dtdalke
Dtdalke's Avatar
Default ODBII P0108 on 2006 base
I have a P0108 coming up constantly. Since I don't think it even has a MAP Sensor what is causing the code?
Dtdalke is offline
Old 11-13-2012, 12:58 PM
kevinmalec
kevinmalec's Avatar
I am familiar with the MAF (Mass Air Flow Sensor).
Is your car riding OK?
I searched the forum regarding the P0108 code and I did not see any threads that had a resolution.
Do you have any performance mods on your car?
Once guy removed his negative battery cable for about 30 min. and the code went away.
kevinmalec is offline
Old 11-17-2012, 09:39 PM
tx_zstang
tx_zstang's Avatar
You have a EGR module issue. Check the vacuum line to the EGR module, and the little hose connecting the two sections together. Make sure nothing is broken, no holes in the housing.
The MAP sensor on the V6 is inside that EGR module. I have a spare one, but need to make sure it still works.
tx_zstang is offline
kevsgt
10-09-2015 10:12 PM
UrS4
10-03-2015 06:23 AM
ChampInSD
10-02-2015 04:55 AM
BeatnikFink
10-01-2015 08:00 PM
Florida Regional Chapter
09-30-2015 08:04 PM
Quick Reply: ODBII P0108 on 2006 base
