s197 interior cabin light always on 2007 v6 pony package
Old 02-09-2013, 08:23 PM
IvanRad
IvanRad's Avatar
Default s197 interior cabin light always on 2007 v6 pony package
Since day one my interior lights havent worked. finally i decided to do something about it. heres the catch they are always on unless you unplug the battery . it always stays on so i decided to unplug the wire that connects to the cabin light. i havent used the interior light at all. so i took a look at it and all the cords are normal nothing fried . the button seems to be fine it just doesnt actually turn the interior lights off.
IvanRad is offline
Old 02-09-2013, 08:52 PM
Moderator
JimC's Avatar
It may be a simple thing. By any chance is the "wheel" that you use to adjust the brightness of the dash display turned all the way up? If so, that is lighting up the interior lights -- and it wouldn't be the first time it happened to someone. I remember someone else having the same issues and that was the problem for them.
JimC is offline
Old 02-09-2013, 10:24 PM
Nuke
Nuke's Avatar
Originally Posted by JimC
... is the "wheel" that you use to adjust the brightness of the dash display turned all the way up? If so, that is lighting up the interior lights -- and it wouldn't be the first time it happened to someone. I remember someone else having the same issues and that was the problem for them.
Exactly what I thought when I read the OP's thread.
Nuke is offline
Old 02-09-2013, 10:42 PM
GrayPony
GrayPony's Avatar
You just had a water leak problem... I would check the SJB
GrayPony is offline
Old 02-11-2013, 06:10 PM
IvanRad
IvanRad's Avatar
btw water leak didnt doo shiiiitt to my mustang nuthin. Shes sealed up and running. no damage to SJB and my radio works perfectly now. i guess the water was just causing some glitches. Ive pressure water tested the stand and shes dry as a bone on the interior.
Now for some mods
IvanRad is offline
Old 02-25-2013, 03:31 PM
cema93
cema93's Avatar
hey graypony i sent u a private message
cema93 is offline
mungodrums
10-07-2015 04:01 AM
jrrhd73must
10-02-2015 09:17 PM
ChampInSD
10-02-2015 04:55 AM
GTJIM
09-23-2015 09:59 AM
2016PP
09-23-2015 09:51 AM
Quick Reply: s197 interior cabin light always on 2007 v6 pony package
