"Bambi Mod"
Old 08-30-2013, 09:12 PM
dagored11
dagored11's Avatar
Default "Bambi Mod"
I have an '07 F150 that has the "Bambi" mod - the ability to have the fogs AND the hi-beams on together for extra lighting on dark country roads. It works on 04-08's. My wife has an '06 Mustang Pony - anyone know if this works on the 'Stangs??
Thanks,
JA
dagored11 is offline
Old 08-31-2013, 07:43 AM
Nuke
Nuke's Avatar
I could have sworn I had a write-up or marked-up wiring diagram for that. If I find it, I'll let you know. Otherwise, you should be able to Google it.
Nuke is offline
Old 08-31-2013, 10:10 AM
157dB
Cut & Paste Expert
157dB's Avatar
Its not available OEM as delivered.
But with a relay and some wire...
I did the deer fogs/high beams mod.
1 relay is all thats needed.
High beam wire powers the relay coil
and the contacts power the fogs
independent of the vehicle wiring.
157dB is offline
Old 08-31-2013, 01:35 PM
Nuke
Nuke's Avatar
Sweet, 157db. Thanks.
Nuke is offline
Old 09-01-2013, 03:12 PM
flyhigh@mach1
flyhigh@mach1's Avatar
How about just the fog lamps on the Pony Pkg during day w/out running lights on? I like to use them as day safety lights but to use them I have to turn on light switch to 1st position and my radio lights and clock dim so I can't read them.
flyhigh@mach1 is offline
Old 09-07-2013, 08:19 AM
2005Redfire6
2005Redfire6's Avatar
Bambi mod huh, thats new to me! Luckily I have a wiring harness/separate switch for my fog lights since my car didn't come with any so I can go "Bambi" regardless!
2005Redfire6 is offline
Rambit
05-18-2013 04:36 AM
Tormentor
12-14-2008 04:45 PM
DaMach04
Mustang Videos
02-21-2006 05:54 PM
Quick Reply: "Bambi Mod"
