V6 Driveshaft and Rear Swap
I've looked trough all most all of the pages and searched but could not find a tread with an answer I'm sorry in advance it there was one. I'm looking at swapping out my drive shaft to an aluminum one and the rear to an 8.8. I was wondering if anyone knew the difference between the V6 and V8 drive shafts? If the u-joints are the same and its just the trans flange is different then I'll just buy the GT D/S and swap the flange on the trans end.
It is the pinion flange, not the transmission end. If you are getting a rear end from a 2005-10 you have to swap the pinion flange, or have them build your shaft with the correct end on it.
But if the rear end is from a 2011 + then it has the correct pinion flange
Sent from my SPH-L720 using IB AutoGroup
Galactic
04-29-2019 02:56 PM
Luke9222
10-22-2015 11:55 PM
Dragonus18
09-09-2015 01:21 AM
