Oil filters?
Old 03-13-2014, 10:12 PM
Sixxtwelve
Sixxtwelve's Avatar
Default Oil filters?
So its that time again, time to change the oil... the only thing is, i bought a motor craft fl820S oil filter for my 2010 4.0, but it seems to have a smaller one installed on it (looks like the fl500s). Im confused as to why every chart I've seen has said to use a 820, but the ford dealership i got my mustang from has a 500 on it. Can anyone enlighten me?
Sixxtwelve is offline
Old 03-13-2014, 10:45 PM
Goldenpony
Goldenpony's Avatar
I just looked on the RockAuto catalog which is usually pretty good. It calls for the FL820S filter for the 2010 Mustang, 4.0 L.
Goldenpony is offline
Old 03-14-2014, 07:17 PM
Sixxtwelve
Sixxtwelve's Avatar
Thanks boss, I'll go ahead and swap the filter and see if I run into anything
Old 03-15-2014, 10:04 AM
2005Redfire6
2005Redfire6's Avatar
It would be the 820S being the 4.0, hell I think the 4.6 uses it too.
2005Redfire6 is offline
Old 03-15-2014, 12:09 PM
jz78817
jz78817's Avatar
the FL-500 and FL-820S are physically interchangeable; same bore size and thread on the center and same gasket seating surface. Just like how you could install a Motorcraft FL-1A (the classic 302/351 Windsor filter) on a 2.2/2.5 liter Chrysler engine. maybe the 500 was used because it was a bit cheaper, or it was what they had on hand.
jz78817 is offline
Old 04-09-2014, 05:42 PM
XGC JACOBS
XGC JACOBS's Avatar
I've been using magnetti marelli filters on my 4.0 with no problems. Haven't really heard much about them though hopefully they are ok.
XGC JACOBS is offline
Old 04-09-2014, 06:44 PM
Nuke
Nuke's Avatar
You can't go wrong with the Motorcraft filter unless you're running your oil beyond 7500 miles as I and others here do (full synthetic). It's rated well. IIRC, the FL500S is used on the newer Stangs but is interchangeable with the FL820S as mentioned.
Nuke is offline
Old 04-13-2014, 05:23 AM
Forza_Roma
Forza_Roma's Avatar
And which filter should be used with full synthetic oil?
Forza_Roma is offline
Old 04-13-2014, 12:47 PM
Joenpb
Joenpb's Avatar
Amsoil & Royal Purple are both designed for longer oil change intervals.
http://www.bobistheoilguy.com/forums...rp#Post2551795
http://www.fram.com/oil-filters/fram...il-filter.aspx
Joenpb is offline
Old 04-13-2014, 02:12 PM
Nuke
Nuke's Avatar
The Amsoil Ea filters are rated for 25,000 miles but I personally wouldn't feel comfortable going much beyond 15k miles until I did some test or analysis. I typically go 10k-12k miles on the Amsoil Ea and the Mobil1 filters.
Nuke is offline
Quick Reply: Oil filters?
