Purchased a 8.8 GT rear end.
Old 03-26-2014, 08:05 PM
pascal
S197 Section Modder-ator
pascal's Avatar
Originally Posted by Steve@Tasca
When swapping the flange you just have to be careful to re-torque the nut to the same spec it was previously so you don't alter the pinion depth which is controlled by a crush sleeve.
Good point there... most non-pro folks screw that step all up.
pascal is offline
Old 03-26-2014, 09:44 PM
Moderator
JimC's Avatar
What model year is the rear end from? If it is a 2011+ then you don't need to swap the flange because the 2005-2010 V6 will direct mount to it.
If it is a rear end from a 2005-10 model year GT then yes, you do have to swap the flange.
JimC is offline
Old 03-27-2014, 05:35 AM
Stangbass
Stangbass's Avatar
I wish I could find a 8.8 for a decent price. Most of the used ones I find, by the time I pay for the rear end plus freight and new gears I'd be better off buying a new one with gears installed from AM. What's the deal with people wanting 600-800+ bucks for their used 50K rear ends?
Stangbass is offline
Old 03-27-2014, 12:07 PM
Steve@Tasca
Former Sponsor
Steve@Tasca's Avatar
Originally Posted by 2010v6vert
I will keep that in mind thanks, I sent a PM for some prices
PMd you back
Steve@Tasca is offline
Old 03-30-2014, 05:20 PM
stoneblue
stoneblue's Avatar
[QUOTE=Steve@Tasca;8367094]When swapping the flange you just have to be careful to re-torque the nut to the same spec it was previously so you don't alter the pinion depth which is controlled by a crush sleeve.
Would this be pinion depth or bearing preload?
stoneblue is offline
Old 04-18-2014, 12:31 PM
Steve@Tasca
Former Sponsor
[QUOTE=stoneblue;8369815]
Sorry for the delay responding, I'm no expert on building rear ends I just try to share the little bit I do know.
I believe it controls preload but someone more experienced than I am might be able to give a definite answer.
-Steve
Old 04-22-2014, 09:31 PM
Sarge1400
Sarge1400's Avatar
[QUOTE=Steve@Tasca;8377764]
-Steve
Pinion depth is set with shims, preload is controlled by the crush sleeve.
Sarge1400 is offline
Old 04-23-2014, 10:44 AM
Steve@Tasca
Former Sponsor
[QUOTE=Sarge1400;8379559]
Thank you.
mtgldr
02-03-2024 09:00 PM
mmarsh3014
Wheels & Tires
10-20-2015 09:08 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Dragonus18
09-09-2015 01:21 AM
amandahchase
09-03-2015 10:09 AM
Quick Reply: Purchased a 8.8 GT rear end.
