Group Buy SuperSixMotors Cams 4.0 (05-10) V6 Mustang
Old 07-30-2014, 08:39 PM
JJHoover
JJHoover's Avatar
Originally Posted by JimC
Ivan it has nothing to do with the number of cylinders. With the timing chain on the back of the passenger side head it is very difficult to do. The 4.6 is easy and everything accessible. Not the case on the 4.0. You can't watch a video or read a swap on the 4.6 and apply that to the 4.0. Very different set up. The set up means you have LESS room to work with despite 2 fewer cylinders
The easiest way to swap on the 4.0 is pull the engine so you can get to the back of the passenger side head. I'm not sure it can be done with the engine in the car, at least not easily
not to mention these cams have to be degreed, there is no way to get a degree wheel on the back of the motor while it is in the car IMO.
If anyone has done it I would like to hear how.
JJHoover is offline
Old 08-03-2014, 04:48 PM
2005Redfire6
2005Redfire6's Avatar
There was a guy over on the collective that has done it, I forget the name. It sounded good but he also had a Vortech with them. Not sure how they were installed.
2005Redfire6 is offline
Old 08-14-2014, 01:35 PM
Stang-aholic
Stang-aholic's Avatar
these 6ers sound good with cams, but you have to drop the motor... not really worth all the work. just save up a little more and get FI
Stang-aholic is offline
flash_xx
10-16-2015 07:23 AM
ChampInSD
10-02-2015 04:55 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
09-25-2015 06:30 PM
Quick Reply: Group Buy SuperSixMotors Cams 4.0 (05-10) V6 Mustang
