Coolant leak
Coolant leak
So my fiance has a coolant leak in her mustang its gradually gotten worse over the past few weeks. Due to this I think ive pin pointed the location only issue is I dont know what its called so im gonna add some pictures any help is appreciated. Its on the lower part of the car behing the radiator.
More likely it is the thermostat housing, leaking down the front of the engine. Anytime a 4.0 has a leak the thermostat housing is the first place to check. It usually splits on the back side, and is often mistaken for a bad water pump. Before doing anything inspect the thermostat housing carefully.
There are several threads about it, maybe even a sticky on how to replace it. The thermostat housing is a simple job, about a half hour.
Mine started leaking where the upper and lower thermostat housing come together. Over time the plastic thermostat housing warps. I replaced it out, which fixed the coolant leak at that time. Well, 6 months later, I saw coolant laying on my garage floor once again. It turns out I have head gasket leak and the coolant leaks into the "V" of the engine and slowly drips onto the ground. It's an external leak and does not cause any damage. The smell is awful at times. :/
