Procharger Install
Procharger Install
I've started trying to bolt a few things on slowly over the last couple of days. So far I've installed those pretty lime green 42lb injectors
Took off the radiator hose, belt, and idler pulleys. Realized I need a half inch longer bolt that goes into the head, and a 4- 5 inch longer bolt that goes into the lower left hand side of the altenator. I also realized I needed a new idler pulley, so I guess I'll have to buy one if I still use it. (not a bad idea to check your own, my car has 50,000 miles and the idler is loud and worn out)
I bolted the charger bracket on to get an idea of where things were going to be... If this isn't right someone please let me know:
I started to mount the intercooler when I realized the power steering lines that run from the drivers side to the passenger side right in front of the rack and pinion were going to have to find a new home.
here is pic of the intercooler:
And where it goes, you can see the lines in front of the radiator that are in the way. I think its suppose to go in the area marked "1", but i'm consdering trying to take the foam out thats behind the bumper cover and mount it there. It would be closer to the front like this, which would look cooler, plus I wouldn't have to re run my power steering lines. any tips?
anyways... here it is... how its going to sit for a while anyways, hood up, in a garage. Thats just what makes a mustang feel like home anway
RE: Procharger Install
$1200 for:
P1SC head unit
Bracket
3 core intercooler
Piping
bypass valve
42lb injectors
Pro M mass air meter
BBK throttle body
a piller gauge pod with autometer c2 boost and a/f
one other thing to procharger guys... how does your intake thats coming into the charger fit around the a/c lines?
P1SC head unit
Bracket
3 core intercooler
Piping
bypass valve
42lb injectors
BBK throttle body
hmmm... I see I see...
http://www.vortechsuperchargers.com/...FH4FL218im.pdf
There is lots of good info here..
Procharger may be a good product, but their customer service is no where near vortechs.
Honestly you have to push the a/c lines down. Just bend em its not a big deal. You could honestly just bypass the power steering cooler. Unless you are gonna use the car as an autocross or road race car the cooler really isn't that necessary.
The intercooler goes in front ofthe radiator and the piping is a bit of a B1TCH to put on. Heres apic of my car without the bumper on you can see the power steering cooler in front of the intercooler (thats a custom mounting point) and the intercooler mounting point.
ORIGINAL: Quicktime_GT
the a/c lines?
ORIGINAL: 2000GT4.6
the vortech manual just has you bend them out of the way.
Just don't get stupid and go crazy on them... do it slowly over time (push gently and do it slow )
The biggest MOST IMPORTANT thing to do when installing a supercharger (or anything) is to TAKE IT SLOW and never ever ever force anything. I almost screwed myself trying to get in a hurry, didn't read the manual all the way andI put the wrong bolt (like .5 inch to short) in the bracket for the blower... I almost stripped out the tapped hole on the blower.
Some more pics of your install would be sooooo helpfull ...
Yep.
Where did you get that kit for 1200? That intrigues me, I am contemplating buying an FI route for my stang and just wondering
