My steeda tri-ax won't fit! Help!
So I got my tri ax today, and tried to install it. I got as far as removing the stock shift lever and taking out the plate with the rubber boot. As I went to remove the 4 13mm bolts that hold the shift mechanism to the tranny I realized it wasnt gonna work. The two bolts that are toward the rear section are only exposed a bit more than half way. Meaning I cant get a socket or wrench in there to get them out. WTF? It looks like the only way to get at the bolts is to cut away a small part of the car or remove the tranny. Both of which i'm not about to do. Anyone else have this problem? Any suggestions? thanks
jwog666
12-27-2021 08:09 PM
09-24-2015 09:18 PM
